'89 4.9 with EGR code 84
Old Mar 28, 2015 | 07:54 AM
aj88V's Avatar
aj88V
Generally starts and runs well. Idles a little rough. Was on the highway last weekend and the truck sounded "fut-fut-fut" like it was missing on a cylinder when I stepped on the gas, but it easily held 70. Then later traffic slowed and she had trouble getting up to speed. Got off the highway and she didn't want to rev past 3500. Stopped, cooled down for 10 minutes and she was good again.
I just got an OBD-1 reader and it's pulling code 84 on the Key-On, Engine-Off (KOEO) codes. The book just says EGR (exhaust gas recirculation), but this website http://www.troublecodes.net/ford/ says
<table border="1" width="566"><tbody><tr><td align="center" width="28"><center>84 </center>
</td> <td align="center" width="63">
</td> <td align="center" width="453">
EGR Vacuum Regulator – Solenoids
</td> </tr> <tr> <td align="center" width="28">
EGR cutoff solenoid – Solenoids
EGR Vent solenoid – Solenoids
</td></tr></tbody></table>
I have the 3 book OEM service manual, but it says there's a separate emissions book I need.
So where to start?
Old Mar 28, 2015 | 10:21 AM
aj88V's Avatar
aj88V
Just tested the EGR valve itself. The diaphragm holds vacuum, the valve works - manually putting vacuum on it with a hand pump will vary idle speed and eventually kill the motor. This is good news, as that EGR valve is expensive!
Now need to test the EGR solenoid and the position sensor.
Thedonk
47
Jun 22, 2016 11:52 AM
angela1881
Bronco II
17
Feb 13, 2014 10:46 AM
Staveys150
Mar 11, 2011 11:55 PM
sjser
Jan 12, 2006 05:16 PM
riverrats007
Dec 12, 2005 10:50 PM
