Need picture, PS pump bracket please!
Old Mar 27, 2015 | 12:05 PM
mismith's Avatar
mismith
Can someone please post a pic. of the correct mounting bracket for a Thompson pump on a '71 F100 with 302? I want to see what I am looking for. I have the pump and need the bracket for 302.
Thanks!
Old Mar 27, 2015 | 03:56 PM
JEFFFAFA's Avatar
JEFFFAFA
Thanks!
There are multiple brackets. That way you can adjust the belt. But you're also going to need pulleys, sample belt,nuts,bolts, washers,spacer,etc. Here again it would be best to get all off the same donor 302. IMHO car or truck. 1977 the last year Ford used the Thompson pump.
Old Mar 27, 2015 | 04:35 PM
mismith's Avatar
mismith
I realize there are multiple ones that will work. I have the correct pump and pulley already. I want the original style bracket that would have came on it in '71. That's why I want a picture of the correct original one used by Ford on the '71-'72 F100. I am in no hurry and do not wish to use a bracket from another year, just because it will work.
The problem so far with all the junk yards is that all the brackets and pumps get gone first. Just need someone with a bone stock original to post a few close ups of what I need.
Thanks!
Old Mar 27, 2015 | 04:52 PM
JEFFFAFA's Avatar
JEFFFAFA
Thanks!
Yeah but you'll prolly need water pump and crank pulleys also.
Old Mar 27, 2015 | 11:07 PM
yellow truck's Avatar
yellow truck
Here is mine.
Old Mar 27, 2015 | 11:30 PM
ultraranger's Avatar
ultraranger
PS brackets for an FE engine won't be the same as ones for a 302.
Old Mar 28, 2015 | 07:10 AM
mismith's Avatar
mismith
Yep, need a pic. like that of a '71 or '72 with 302 that was born with PS. I have a friend who has several and he said a lot of them will work, but.....which style is correct for a '71 is the question.
Thanks!
Old Mar 29, 2015 | 07:23 PM
mismith's Avatar
mismith
I think I am halfway there? I went digging through some parts I had from a '68 LTD that we had to get the 390 out of. I found this pump and bracket. It appears that the adjustment bracket will work on my 302. The pump mounting bracket does not line up though.
gator1965
May 10, 2007 05:01 PM
Red West
Jul 29, 2002 06:30 AM
