Overdrive pulley
Old Mar 27, 2015 | 02:56 AM
Will Bite's Avatar
Will Bite
Overdrive pulley
Has anyone used a overdrive pulley on there 6.0 and if so did it really make a difference at idle, and where did you get it.
Old Mar 27, 2015 | 03:31 AM
dannyboy950's Avatar
dannyboy950
What are you calling a overdrive pulley. What exactly is it on.
Old Mar 27, 2015 | 04:59 AM
87crewdually's Avatar
87crewdually
I have not used one on my 6.0 but I've seen them for sale on eBay. It's just a smaller pulley so it turns the alternator faster.
Old Mar 27, 2015 | 05:06 AM
Will Bite's Avatar
Will Bite
Found one one Ebay just wondering if it's worth the 15 bucks . http://m.ebay.com/itm/170925366867
Old Mar 27, 2015 | 06:26 AM
jsm180's Avatar
jsm180
I bought a Motorcraft from amazon. Depends on your alternator how much it helps, some of the high output ones need more rpm to get the output at idle.
Robot Check Robot Check
Old Mar 27, 2015 | 07:56 AM
dannyboy950
AAAHHH OK makes sense now. Sorry my brain wasn't in gear yet when I saw that. Never actually heard it called that before. LOL
Guess I am just a backwater swamp boy. LOL
Old Mar 27, 2015 | 11:03 AM
diesel_dan's Avatar
diesel_dan
I've got one on the shelf -- you are right I expect it only to help at idle. I haven't been in a hurry as I still see decent volts w/ glow plugs on and then as soon as they kick off I'm up to high 13s low 14s at idle. We have the factory 140A "upgraded" alternator -- ordered truck that way. Sometimes it's just luck as we (or hardly anyone back then) had no clue on FICM, Injector issues low voltages could cause. We just knew we'd have a camper and horse trailers with batts we'd be charging off the truck.
I put solar on the camper, so I never tie the two together...
Ford should have put the 140A on as the smallest alt in the 1st place.
There also is the whole upgrading the charge wire route you can do too...
Old Mar 27, 2015 | 11:04 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
It helps the stock 110, 140 or the 3G 130 amp at idle.
You want the 57-58mm pulley.
Josh
Old Mar 28, 2015 | 03:21 AM
Yahiko's Avatar
Yahiko
Josh
What he said ^^^^
Ebay for about 12~14 $
Sean
Old Mar 28, 2015 | 09:24 AM
mattdoc88's Avatar
mattdoc88
Does anyone know the max allowable speed for the alternator? And the factory alt pulley and crankshaft pulley diameters? If someone gives me that info, I'll check that it doesn't overspend the alt, which can lead to failure. Also I'll give the alt rpm with both pulleys based on engine rpm.
Old Mar 28, 2015 | 09:57 AM
dannyboy950
Are you factoring in the other unknown pulley dia. or just use overall belt length?
There seems to be two schools of thought on this, intermediate pulleys do not count belt lengh is sufficent. The other says you need to factor in all pulley dia.
Myself I useually get lost in the equations.LOL
Old Mar 28, 2015 | 10:24 AM
xaviar's Avatar
xaviar
I've been using an overdrive pulley for a year. No problems. And as stated, works better at idle. this the one i bought as was referenced here. I also installed the 140amp upper alt from a dual alt SD setup until i upgrade the big wire kit and 250amp setup from Ed at FICM repair.
http://www.ebay.com/itm/170910011638?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Mar 28, 2015 | 01:51 PM
Will Bite's Avatar
Will Bite
That was the one I was looking at. I think I'll give it a try. Thanks
Old Mar 29, 2015 | 07:30 PM
mattdoc88's Avatar
mattdoc88
You need crankshaft pulley diameter and alternator pulley size. Using the ratios of those you can figure out for each engine rpm, what the alt rpm is. All the other pulleys in the belt train and the belt length itself are irrelevant for this calculation. It's a simple calculation once you know how to math the numbers together.
akblackfoot
Jul 29, 2017 05:49 PM
Hammy211
3.0L V6
Sep 24, 2003 09:47 PM
10charlie2
Dec 19, 2002 10:21 PM
kwing
Mar 18, 2002 05:01 PM
