EOT not reading right
I did ceck voltage from the 42 way connector to PCM got the same 3.95V I'v ruled out bad wiring between the two.
First, Back-Probe the PCM Pin. That being said.
***YOU DO NOT WANT TO USE TWO BACK PROBES ON A PCM UNLESS YOUR VERY CAREFUL.***
The chance of a short increases exponentially.
Use the Sensor's Ground to complete the Circuit. If you get 5v, the problem is in the circuitry ((+) wiring)).
If you don't, Back Pin the Ground on the PCM (-) and use the (+) in the Sensors Feed Side. if it increases, its in the Ground Side of the Circuit.
If you determine it's in the circuitry, then you begin checking circuits and junctions.
With my mental reset, I now wonder about the 5 volts. I have seen PCMs with max sensor voltages all over the spectrum, and I rarely see 5 volts anywhere. It's my understanding the PCM provides 5ish volts, and the PCM compares this voltage to the sensor input - automatically compensating for low or high voltage references.
I know from my own experience that 3.95 volts may be straight reference voltage, then it's a matter of learning what the sensor output is in relation to that and ground.
There area a myriad of things that can affect the 5vR. As for a normal reading of 5vR, several things affect that. Batteries, Charging System, etc. For the most part "my rule of thumb is .5v. Anything greater than that, there is an issue. The great thing about voltage is it's either there, it's reduced, or its not there. It can't lie. All Scan Tools that display temperature and pressure are merely code written to use the voltage and convert it to another.
On the EOT, the three "key" voltage readings are for start up (Glow Plug Time On / Fuel Bowl Heater / and Fuel Delivery (keep it running). Of course there are additional sensors which al must have input such as the CMP and AIT.
I was attempting to get him to perform a few tests. First off he's getting a *F reading from somewhere. And, he doesn't say "how" he's getting it. Scan Tool, Gauge, etc. Un plugging the sensor improves performance. Well, that Sensor is a Thermistor.
A shorted thermistor will not pull-down the entire ref. circuit due to the internal resistor in the PCM for thermistor circuits.
While measuring reference voltage with the key on, (usually at the EOT or ECT because of easy access) start unplugging the sensors one at a time.
The System reference can be shared (externally from the PCM) with pots, psi sensors, and Hall effects but never with thermistors. A shorted pot., psi sensor, Hall Effect may pull down the entire System Reference Circuit, including all of the internal circuits that use this same reference voltage.
When he was testing, he was testing at the 42 Pin Connector and sensor. Grounds may be shared between any inputs, But, Signal wires are never shared between sensors.
The very simple test is to Find the sensor that causes the reference voltage to return to 5v when you unplug it.
If you still have no 5v ref. with the sensors all unplugged, then you must disconnect the PCM and measure for a short to ground on the reference circuit. (Sensors still unplugged)
No short to ground then you have a PCM problem. Make sure you check all PCM powers and grounds before replacing the PCM.
So, saying he has a "Bad Sensor or Circuit" is referring to something is "pulling the voltage down". He's got to find the offender before he knows what to fix.
One experiment I have been waiting a few years to do because I have not had an issue with EBV Sensor is that everyone states they adversely affect fuel mileage and performance when they're dirty or clogged.
I don't think its as much the sensor as it is the sensor is drawing the 5vR circuit down causing the vehicle to run in a different strategy than the warn engine mode because the sensor is commanding more current and the PCM can't maintain it.
So, If I ever get one (not likely in the deep south) I will scope it and analyze the data to prove or disprove my hypotheses.
So, if anyone out there is planning on cleaning the EBV because they're getting bad fuel mileage. Take a moment and send me the 5vR before and after for comparison.
What was your reason for changing it?
Was your fuel mileage suffering?
Did it get better following the change?
TXD: C410F1221310
RXF: 046245130610
RXD: 3010
MTH: 00090005F060
If you by chance are referring to the ECT, Engine Coolant Temperature, the Scan Gauge II acquires that from several sensors as the ECT is not supported on Automatic Transmission equipped vehicles (the wiring is from the Thermister to the Gauge).
ETC Display on a Scan Gauge II is:
TXD: C410F1221139
RXF: 046205110639
RXD: 3008
MTH: 00010002007F
** It will read "out of range" 250*F + until the EOT (engine oil temperature reached 140*F or >).
Andy
Here's an update with the sensor connected the voltage input was 2.95v with 0 current
Data with 1000 miles after changing EBPS, Tube, manifold fitting
Reason for changing is from reading the forums on the possibility of having a 100% sound running truck.
Was dealing with a no start at the time so I can not honestly say what mileage was.
The wife and I recently did a 12 hour trip 754 miles and the mileage was pretty decent approximately 17.5 MPG
Robert
