Idm
Old Nov 6, 2016 | 11:24 AM
Texas 7.3's Avatar
Texas 7.3
Idm
Hi i have a 99 7.3 question is can an idm be bad and still pass a buzz test got code 1298
Old Nov 6, 2016 | 06:16 PM
Tom's Avatar
Tom
Moved to the 7.3L forum.
Old Nov 6, 2016 | 07:29 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
If the truck runs the IDM is working. No other codes? Whatcha using to read the codes?
I'd clear that code and see if it comes back.
What symptoms ya got there?
Old Nov 6, 2016 | 07:36 PM
Texas 7.3's Avatar
Texas 7.3
It sat for about a week and now has no power and rough idle i changed icp because it had oil in the plug. i also attempted to ohm uvhc but not sue if i did it correctly. i drove it to a diesel shop in town to have it scanned and i think it was a matco scanner. not sure about other codes. he just said it was 1298 and needed a new idm
Old Nov 6, 2016 | 09:18 PM
pirschwagon's Avatar
pirschwagon
Do you have a Chip or a Programmer?
P1298 is "normally" associated with another code. If you're seeing it, the Scantool used appropriate for the Truck. Unfortunately, the only way to be certain is to send the IDM for evaluation or use a known good one.
Can you get an App or Scantool to monitor system sensors in hopes of eliminating other possible causes?
noober0x
Sep 10, 2016 08:49 PM
bbryson
General Automotive Discussion
Jul 7, 2011 12:33 AM
AMG-SM
46
Mar 7, 2011 07:15 PM
racingtom
Apr 2, 2007 08:58 PM
Clodbuster
Mar 13, 2004 07:42 PM
