acceleration ?
Old Apr 6, 2015 | 07:36 PM
fordman75's Avatar
fordman75
Something is wrong!! Even with a 1V carb you should have no problem going faster then 65mph!
Did you recurve the distributor when you did the swap? Did you check the timing advance ( mechanical and vacuum ) ?
If you timed it using the timing marks on the balancer, did you verify the timing marks were correct? The outer rings on the balancers have been known to slip. meaning the timing marks are off.
driverreturnonfoot
1978 - 1996 Big Bronco
Mar 28, 2011 02:42 PM
kchaps72
Feb 17, 2009 09:31 PM
Rocket Doc
Mar 15, 2007 01:36 PM
grapplechamp
Engine Swaps
Oct 8, 2004 10:07 PM
Fordsarethebest
Dec 14, 2002 11:34 AM
