1978 - 1996 Big Bronco
79 Bronco stalling problem
Old Mar 25, 2011 | 07:57 PM
driverreturnonfoot's Avatar
driverreturnonfoot
Was driving down the road and all of a sudden my truck started tot lose power could not accelerate it seemed like it was flooding out. Was in the shop not to long ago had a tune up and a few other little issues to clear up. I knew it has to do with the fuel air mixture but it was part of the tune up what else could it be?
Old Mar 26, 2011 | 07:28 AM
greystreak92's Avatar
greystreak92
There are a host of possibilities. Clogged fuel filter, bad plunger/piston in the carb, fuel pump failure, ignition issue...Duraspark modules rarely give any warning when they decide to quit.
With the "flooding", if it is indeed doing so, it could be a carb float issue which isn't likely to have been addressed with a regular tune up.
Old Mar 26, 2011 | 10:14 AM
driverreturnonfoot
I had the carb rebuilt while it was there also. As far as what you suggested all of that is brand new this is why I am stumped on what else it could be. Someone suggested that I should replace my vacuum advance on the carb to an electronic one because I have the connectors for it and that might help the problem. Could this also help?
Old Mar 26, 2011 | 01:23 PM
Anafiel's Avatar
Anafiel
I'm assuming you replaced the ignition module?
New ignition modules don't = working modules.
I have heard of people going through 3 - 4 early failures on new (cheap Chinese) modules, before resorting to a JY module that worked.
Old Mar 28, 2011 | 02:42 PM
driverreturnonfoot
Tested it it is working fine. I heard of that too that is why I went straight to the good ones.
kerm7807
6.2L V8
15
Dec 10, 2015 09:47 PM
J ballan
Sep 26, 2015 09:50 PM
bizzelj
Sep 22, 2015 11:52 PM
Sparky83
Aftermarket Products
Aug 31, 2015 07:41 PM
johnsmart
13
Jul 27, 2015 10:04 AM
