acceleration ?
Old Mar 24, 2015 | 05:38 AM
roadrash63's Avatar
roadrash63
acceleration ?
Hey guys
I am trying to figure out why my truck accelerates faster at half throttle?
stock 1 barrel 1979 carb.
1985 f 250 with a NP 435 and 3:55 gears 4x4...
Old Mar 24, 2015 | 08:14 AM
AbandonedBronco's Avatar
AbandonedBronco
Are you meaning that it accelerates harder when you are at half throttle than when you are at full throttle?
You say you have a '79 carburetor in an '85 year truck. Do you still have the feedback ignition system? Or have you converted it to DuraSpark II or some other aftermarket ignition setup?
Old Mar 24, 2015 | 10:18 AM
1986F150six's Avatar
1986F150six
My first guess is that the OP was indicating that the engine was at about 1/2 of its normal operating range??? If that is correct, the engine likely is @ ~1500 - 1600 RPMs which is right at the maximum torque.
Old Mar 25, 2015 | 06:23 AM
roadrash63's Avatar
roadrash63
Abandoned bronco,
I have completely removed the emissions ex for the pvc.
I have a gm hei module...I kept leaving the key on and frying ds 2 modules ! Using a ds2 distributor rebuilt from advance auto.
New fuel pump on the block and filter ,rebuilt carb.
Old Apr 2, 2015 | 10:39 AM
Parsedout's Avatar
Parsedout
If we take your question literally (and I think this is what you mean), you accelerate faster when you're at 50% throttle than at full throttle. I can tell you I observe a similar situation. Here's my gut feeling...with a 1bbl carb there isn't a massive difference in CFM from 50% to 100% throttle opening, ie. the air flow is not twice as much at WOT, it's not a linear relationship. With most vehicles when you mash the gas you expect it to move faster than at part throttle, but our tractor engines don't respond the same way. I doubt it's "faster" at part throttle but it just isn't much faster at WOT. That's just my 100% anecdotal experience.
Then again, it could be something like a worn out bore in the throttle plate that as you open the throttle it exposes more of the leak and causes a highly lean condition. Maybe it's time to pull the carb and give it a good once over inspection and maybe even a rebuild kit while it's on the bench.
Or your timing could be out, double check your TDC mark on the harmonic balancer with actual TDC.
You could also grab some carb cleaner and have some fun spraying around all of your vacuum connections to see if you have a leak (just be careful).
Old Apr 3, 2015 | 06:40 PM
roadrash63's Avatar
roadrash63
thank you for the input! I have rebuilt the carb and the throttle shaft is tight relatively... I have timed it using a vacuum gauge.
it runs great I guess it's something I'll have to get use too.
another thing is I have the NP 435 and 3:55 gears I can get it up to 65 and a little more... But after that its done! I like to get on the freeway with that everyone and their mother passing me like I'm standing still!
maybe I'm just running out of carburetor?
I have a autolite 2100 3:56 CFM with an adapter that I haven't used yet... The engine is all stock except for ds2 conversion with hei Module.
Old Apr 3, 2015 | 06:45 PM
Parsedout's Avatar
Parsedout
Something isn't right, I have the same gears and trans and can hold 75 all day if I felt the need. I usually cruise at 65-70 with only relatively little throttle.
Old Apr 3, 2015 | 06:48 PM
AbandonedBronco
Agreed.
Have you done things like check for dragging brakes, plugged catalytic converter, etc? Those types of things can really rob power.
Old Apr 3, 2015 | 06:52 PM
roadrash63's Avatar
roadrash63
I have a new distributor and plugs etc
.holds 20 inches of vacuum, tho i did back it off a little.new exhaust all the way to the bumper.stock air cleaner.
No vacuum leaks
Heat riser not sticking...idk ?
Old Apr 3, 2015 | 06:54 PM
roadrash63's Avatar
roadrash63
breaks are good, new cat.
it's almost a frame off resto on this thing !
Old Apr 3, 2015 | 06:55 PM
roadrash63's Avatar
roadrash63
maybe I'm in the throttle too much???
Old Apr 3, 2015 | 06:57 PM
AbandonedBronco
Cool. Just covering the bases.
Vacuum advance working correctly?
Old Apr 3, 2015 | 07:15 PM
roadrash63's Avatar
roadrash63
Yeah it runs great except for this...
Old Apr 6, 2015 | 02:15 PM
1986F150six
Crazy question, but what type of radiator fan? Is the engine really wound out @ 65 mph or does it just sound like it is?
Old Apr 6, 2015 | 03:06 PM
roadrash63's Avatar
roadrash63
I Have a thermostatic fan.
It doesn't sound like its screaming(no tach)
32in tires 3.55 gears...
Just won't go faster.
