Generator Issue?
Old Apr 7, 2015 | 09:05 PM
Tedster9's Avatar
Tedster9
That's a good sign, I'd say. Have the vendor send you a replacement for the one that is defective.
Old Apr 7, 2015 | 09:36 PM
Joe777's Avatar
Joe777
Well hopefully that problem is fixed. Unfortunately the quality of aftermarket parts for these trucks is marginal at best.
Old Apr 7, 2015 | 11:36 PM
newold46's Avatar
newold46
Originally Posted by Tedster9
Hm, they call it a cutout, but it performs voltage and current regulation as well?
Have read the solid state 12 volt Bosch regulator units for a '72 VW work (for 12 volts obviously)
Good catch! I should never try to think or type before coffee! It is only a generator cutout. I think I was getting ahead of myself when I was talking about hiding it somewhere.
Old Apr 8, 2015 | 06:15 AM
Joe777's Avatar
Joe777
It sounded like a good idea
Old Apr 9, 2015 | 11:20 AM
46fordgal's Avatar
46fordgal
This should be my last question on the generator/regulator issue. Does the paint need to be scraped off of the firewall where the voltage regulator is attached so there is bare metal-to-metal contact for grounding purposes?
Old Apr 9, 2015 | 02:04 PM
Tedster9's Avatar
Tedster9
It needs good ground, yes. There is probably already a separate ground wire from the battery that is attached to the regulator to ensure this. Voltage regulators get confused without a good solid ground reference, or high resistance, corroded connections.
Best to check voltage output at the battery at 1500 RPM, you'll want to see between 14 and 15 bolts, depending on temperature. Then turn on the headlights and heater blower and measure again. Voltage will sag a bit but it should hang in there above 14
Old Apr 9, 2015 | 04:26 PM
Joe777's Avatar
Joe777
My wiring harness had a ground wire for the voltage regulator. I attached it to one of the mounting screws and scraped off some paint around the hole. Really hated grinding off some of the new paint but oh well
Old Apr 9, 2015 | 11:59 PM
newold46's Avatar
newold46
This being a 6v system, seeing that many volts would be a bad thing I think...
Old Apr 10, 2015 | 07:11 AM
Tedster9's Avatar
Tedster9
Doh!! Yeah...
Old Apr 10, 2015 | 07:22 AM
Joe777's Avatar
Joe777
Doh!! Yeah...
"Ya, 220 or 221, whatever it takes" (Micheal Keaton in Mr. Mom?).
Rusty_S
Electrical Systems/Wiring
17
Nov 1, 2017 07:54 PM
Raptorgap
20
Jun 8, 2017 09:58 PM
KawKaw
15
May 15, 2013 08:53 PM
jhaas63
May 15, 2013 01:01 AM
tbm3fan
Jun 18, 2007 10:01 PM
