Hm, they call it a cutout, but it performs voltage and current regulation as well?
Have read the solid state 12 volt Bosch regulator units for a '72 VW work (for 12 volts obviously)
Good catch! I should never try to think or type before coffee! It is only a generator cutout. I think I was getting ahead of myself when I was talking about hiding it somewhere.
This should be my last question on the generator/regulator issue. Does the paint need to be scraped off of the firewall where the voltage regulator is attached so there is bare metal-to-metal contact for grounding purposes?
It needs good ground, yes. There is probably already a separate ground wire from the battery that is attached to the regulator to ensure this. Voltage regulators get confused without a good solid ground reference, or high resistance, corroded connections.
Best to check voltage output at the battery at 1500 RPM, you'll want to see between 14 and 15 bolts, depending on temperature. Then turn on the headlights and heater blower and measure again. Voltage will sag a bit but it should hang in there above 14
My wiring harness had a ground wire for the voltage regulator. I attached it to one of the mounting screws and scraped off some paint around the hole. Really hated grinding off some of the new paint but oh well
This being a 6v system, seeing that many volts would be a bad thing I think...
