351W
Old Mar 23, 2015 | 01:57 PM
SGNADE01's Avatar
SGNADE01
351W
Stranded in Texas! 1990 351 Born Free motor home runs good down the road then just suddenly quits! Have replaced EGR valve, fuel filter, distributor module, dist. cap and rotor, fixed all vacuum hoses and cleaned throttle body. Was at Ford garage for four days. Help!
Old Mar 23, 2015 | 02:00 PM
SGNADE01's Avatar
SGNADE01
Will restart in about half hour to an hour and go another 20 to 80 miles depending on ambiant temp. Back fired the last time it quit and spewed transmission fluid out of the tranny.
Old Mar 24, 2015 | 04:13 PM
timbersteel's Avatar
timbersteel
Any codes?
Could be bad ICM, or the PIP/Stator has gone bad in the PCM.
Do you have spark?
Old Mar 25, 2015 | 05:34 PM
Conanski's Avatar
Conanski
Does the motor just shut off like you hit a kill switch and not restart until it cools off? If so the problem is likely related to one of the distributor modules so I'd suggest swapping in another complete distributor.
BKM-WR3
Apr 5, 2015 04:06 PM
JPalmer81
Jul 2, 2013 01:15 PM
trumsey07
May 29, 2012 02:15 AM
z1121jack
Mar 22, 2010 07:04 PM
z1121jack
Nov 20, 2008 09:03 PM
