6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Swap Powerstroke for Maxxforce??
Old Mar 22, 2015 | 11:03 PM
Hunter40's Avatar
Hunter40
Just a hypothetical question-
It seems like the newer Maxxforce 7 engines with the CGI block are a nice upgrade from the original version. Could one of these be easily swapped into a Super Duty if the original 6.4 Powerstroke outlived its useful life? Or are there other differences that would not allow this to work?
Thanks Hunter40
Old Mar 23, 2015 | 09:11 AM
parkland's Avatar
parkland
I believe it could be done, but it would be a lot of work and not much benefit. That's my take on it.
I think the CGI block is more for noise and weight reduction, more than strength.
I think the blocks are pretty much identical, but the pistons are different, turbo system is different, fuel system is different, etc.
There would be a lot of work involved and custom software, and who knows what else.
Old Mar 23, 2015 | 10:05 AM
dlibson's Avatar
dlibson
In general a swap to a different platform isn't easy or worth it. You'd spend less getting a rebuilt 6.4 and being done with it.
Nothing wrong with an engine swap for fun, or because you can. But just because, eh...
Old Mar 23, 2015 | 02:21 PM
Hunter40's Avatar
Hunter40
My post was inline with your response. Basically I was wondering if it was the same platform. Since it is not, a reman would be a lot easier.
Thanks. Hunter40
Old Mar 23, 2015 | 10:18 PM
parkland's Avatar
parkland
I think even if you did manage to make it work, other issues would arise, such as the way the pistons fit in the 6.4 PSD, and the navistar fit tighter, but doesn't have as high of a power rating, so would it seize right up?
I thought I remember someone actually doing it, reading about it at least.
I remember it sounded like a lot of work. Enough work that you'd be better off just using a 6.4 PSD block unless you liked extra work and had a crazy nice shop to work on stuff.
Fefanatic
May 17, 2018 12:09 PM
Trippytim1152
Apr 24, 2017 08:12 AM
Brad Brown
Engine Swaps
Jan 3, 2017 07:31 AM
dlcslcman
Oct 24, 2002 05:13 PM
