High idle and sometimes sticks around 3000
Old 02-11-2011, 03:33 PM
enzer2406
enzer2406 is offline
enzer2406 is starting off with a positive reputation.
I replaced the TPS on my '91 F-150 5.0L about three months ago. Since then I have been having a problem with my idle hanging around 1500 all the time. Every once in a while it will idle just under 1000 where it belongs. When it's cold it likes to stick up around 2500 - 3000 when I let up to shift. Usually when I tap the accelerator real quick it will idle back down to around 1500. When I replaced the TPS I pulled the entire throttle body off and cleaned it completely, so my butterflies are not sticking and it does not feel like my accelerator cable is sticking. I pulled off the front half of the IAC and cleaned it out really well too. I also scraped all of the silicone sealant off the throttle body and replaced it with a gasket. When I idle it up under the hood the spring is returning the trottle to original position but the idle still sticks around 3000. Is there anything I missed besides buying a new IAC?
Old 02-11-2011, 05:14 PM
Slip ford man's Avatar
Slip ford man
Slip ford man is offline
Slip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud of
TPS might have been installed incorrectly, which would give you a high idle. For example, if you were to remove the old TPS you would first want to scribe a match mark for an easy reinstall of the unit. You would install on the throttle shaft then rotate (clockwise only) to match up to your marks. Have a look here for some tips for adjustment of your new one.
Ford Fuel Injection Throttle Position Sensor (TPS)
Old 02-18-2011, 12:27 PM
enzer2406
Thanks for the help Slip Ford Man I will get to work on it later this week
Old 02-18-2011, 01:19 PM
FordxFour
FordxFour is offline
FordxFour is a splendid one to beholdFordxFour is a splendid one to beholdFordxFour is a splendid one to beholdFordxFour is a splendid one to beholdFordxFour is a splendid one to beholdFordxFour is a splendid one to beholdFordxFour is a splendid one to beholdFordxFour is a splendid one to behold
Just a word of warning. What ever you do, do not mess with the set screw on the throttle body to adjust the idle. That's not what it's for.
Old 02-18-2011, 01:39 PM
enzer2406
Yeah, I caught that from another post I read through. I heard it's factory set and once moved there is no fixing it.
Troyus
04-11-2016 11:08 AM
87-XL-Squared
02-26-2016 07:52 AM
Obs91
02-08-2016 05:08 PM
mike24150
07-05-2013 01:42 PM
knlcasteel
10-06-2010 11:32 AM
Quick Reply: High idle and sometimes sticks around 3000
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
