6.2L V8 Discuss the 6.2L V8
Disable engine from starting..
Old Mar 22, 2015 | 12:12 PM
clintbonnie's Avatar
clintbonnie
With stolen vehicles on the raise, has anyone came up with a quick easy way to disable the engine from starting..? New to the 6.2L.. Do we have an electric fuel pump ? If so, maybe adding a toggle switch to disable the pump.. Any other ideas out there ?
Old Mar 22, 2015 | 06:33 PM
heymrdj's Avatar
heymrdj
Seeing as I don't have common direct access to a 6.2, I don't know how they start (do they have a typical starter solenoid?). With a college buddies old Focus that was in a high crime area, we rigged a hidden switch way up by the accelerator pedal. The switch was wired to a relay placed in front of the ignition wire line that engaged starting. That way the switch had to be turned on for it to start.
Old Mar 22, 2015 | 06:48 PM
Homerunking2394's Avatar
Homerunking2394
Fuel pump wouldnt be the best way since u can drive a little bit with the pump disabled but would work
joshua6430
26
Feb 13, 2017 12:54 AM
AK FORD GUY
17
Mar 19, 2015 08:29 PM
Smokeythebear
1997 - 2003 F150
Jul 17, 2010 12:23 PM
kormelistdijetta
1983 - 2012 Ranger & B-Series
Jun 23, 2006 05:39 PM
cbjr61
Aug 3, 2005 01:43 PM
