2001 f250 power window problem
Old Mar 22, 2015 | 10:13 AM
f350smokelvr's Avatar
f350smokelvr
i just recently bought this truck. when i first bought it the pass side window worked from both door switches. dr side worked when it wanted to. heard relay make buzzing sound in fuse box when i tried putting dr side down. put new relay in, both windows worked for about a week. now pass side does nothing from either door switch. dr side makes relay buzz like before. tried new relay and new master door switch, does the same thing. all fuses are good also. any ideas? thanks
Old Mar 22, 2015 | 07:43 PM
Franklin2's Avatar
Franklin2
Grab the wires and wiggle them in the driver's door jamb. Sometimes they break from the door opening and closing. You won't see it, the copper strands will be broken inside the wire. And the pass side wiring does go through the driver's side.
Old Mar 23, 2015 | 03:25 PM
f350smokelvr
think i figured it out. the relay that was buzzin was #4 in the fuse bopower window one touch down realay) after finding a wiring diagram, i noticed the #5 relay in the fuse boaccessory delay relay)is also in that circuit. i put a new realay in #5. windows both work again and fingers are crossed!
Truckie26
Feb 10, 2018 06:45 PM
mrjimbov
Electrical Systems/Wiring
Nov 23, 2014 07:20 AM
just another truck
Mar 26, 2012 11:31 AM
robs01f250
Aug 30, 2010 01:20 PM
Midnightride42
Oct 22, 2008 10:43 AM
