Window wiring connections..
Old Mar 25, 2012 | 12:57 PM
just another truck's Avatar
just another truck
Hello all,
well today I was driving and all of a sudden, My windows stopped working...since I am not at work, I didnt have all of my eletrical prints with me, so I did search and came back with this old thread.
https://www.ford-trucks.com/forums/1...l#post10996971
It was great, all prints were there!!!
But sadly, I sitll have not found the missing gap.. where did my 12 volts stop at..
the only reason I do not though is, I dont know where the GEM is located, and I sure as hell can get my hands up into the firewall enough to follow the bunble, as it stands right now, it looks like I got into a fight with a cat, with all the scratches..
so. help?? Other wise I am pulling a fuse 12 volt to the switch today..
Old Mar 25, 2012 | 02:09 PM
just another truck
CB 25 is my issue.. as of now, I have not found it.. Bypassing the Acc Delay relay and everything is working.. Wrapping up for now.
Old Mar 25, 2012 | 02:29 PM
PaysonPSD's Avatar
PaysonPSD
Pat,
Are you saying the ACC relay is not operating and when you jumper across 30 and 87 the windows work? If so then CB 25 is not tripped. It should also by a self resetting CB as well.
If the ACC Delay relay is not working check fuse 4 and 22.
You can also swap the Acc Delay relay with the One Touch Down relay.
Old Mar 25, 2012 | 02:38 PM
just another truck
30-87 does not work,
power to 87 from the battery right now is what I am using.
Old Mar 25, 2012 | 02:53 PM
PaysonPSD's Avatar
PaysonPSD
Dumb question since you believe the problem is CB 25, but is there power at 30?
Old Mar 25, 2012 | 04:42 PM
just another truck
I have not put a meter in to pin 30, what I have done is swappwed horn replay for acc relay for window relay, window and horn continue to work.
Didnt have as much time as I wanted to play with this, still believe problem to be at pin 30
did however feel ACC relay "switch" everytime I plugged in or unplugged.
Old Mar 25, 2012 | 05:08 PM
PaysonPSD's Avatar
PaysonPSD
I cannot find where that CB 25 is either.
Edit: Removed wrong diagram posted in error.
Old Mar 26, 2012 | 04:32 AM
just another truck
Looks nothing like either of my fuse panels...but will look again..
Old Mar 26, 2012 | 06:50 AM
just another truck
ANOTHER SYMPTOM IDENTIFIED THIS MORNING, sorry for the caps, interior lights are not working..hmm..need to get back into the prints latter today.. Might be a big indicator.
Back to acc delay relay.. I swapped the one under the hood.. I thought more then once.. is there more, am I missing something.. only time and a meter will tell. Hopefully I will get to it at lunch, but got ALOT going on sadly.
Old Mar 26, 2012 | 11:31 AM
PaysonPSD's Avatar
PaysonPSD
No wonder. I posted the wrong diagram. Deleted it.
wardmoto
1997 - 2003 F150
20
Mar 18, 2011 05:48 PM
Diesel 724
Nov 1, 2010 12:16 PM
robs01f250
Aug 30, 2010 01:20 PM
johare
1983 - 2012 Ranger & B-Series
Aug 21, 2005 10:03 AM
