AIS foam install
Old Mar 22, 2015 | 09:26 AM
Kamstutz's Avatar
Kamstutz
AIS foam install
Does anyone have the instructions on the air box cut out to fit the foam insert?
Old Mar 22, 2015 | 10:03 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Are you referencing the foam/cloth that goes around the battery or the tube that goes into the fender for "increased" air flow?
Old Mar 22, 2015 | 10:22 AM
Kamstutz's Avatar
Kamstutz
Yes I am. Where to cut the hole in the air box? If there are instructions where to place the hole. Better to ask and measure twice than to screw it up by not!
Old Mar 22, 2015 | 10:31 AM
Sous's Avatar
Sous
FTE Emeritus
Found this information, might help you a bit.
https://www.ford-trucks.com/forums/1...e-install.html
Then, about 1/3 the way down the page in the link below there is a Word document with detailed instructions.
AIS Foam Sleeve 99-03 7.3L Ford Powerstroke
Old Mar 22, 2015 | 02:14 PM
Kamstutz's Avatar
Kamstutz
Huge Jet Lag brain fart. I had the web page saved and failed to see the instruction link. Installation complete! Thanks for the assist!
1Fastang
Aug 13, 2009 12:09 PM
steve(ill)
1997 - 2003 F150
Jul 9, 2008 09:41 PM
josephfogg
Aug 24, 2005 09:11 AM
kspilkinton
1997 - 2003 F150
Jun 5, 2004 06:03 PM
Sir_Ham
Aerostar
Feb 12, 2004 02:33 PM
