P2284
Mar 21, 2015 | 09:50 PM
P2284
So I just put a new stand pipe in to fix my no start problem. Now it starts but its slow to start but it does atart. I am now showing a code p2284 my ICP is 6 months old the IPR is not new and the age is unknown. I am overdue for an oil change could that be part of my problem?
Mar 21, 2015 | 10:15 PM
Check icp voltage at koeo.
Mar 22, 2015 | 12:22 PM
Sounds like an injector HPO owing got a nick or something maybe even owing from standpipe
Start it and do low and high idle testing for ICP and IPR%
Test ICPV @ KOEO
Mar 22, 2015 | 12:23 PM
Have you made sure to run it long enough to get an air out with some wot accelerations
Sounds like you may have since it has had time to throw a DTC
Mar 22, 2015 | 07:30 PM
Quote:
Originally Posted by
BLADE35
Ya I have driven around and all that good stuff even stomped on it a couple time. So with koeo my icv is .23 at idle its 1.03 reving to about 2200 rpm its at 1.45-1.48
Mar 22, 2015 | 07:53 PM
Post the ipr at hot idle. A hpo leak will push the idle ipr up from 23 to 25 percent to 25 to 30.
Mar 22, 2015 | 07:59 PM
At 2200 rpm IPR is at about 35.9
Mar 22, 2015 | 08:03 PM
So weirs thing I just reved it up to about 3000 rpm and the code I am getting turns into c2022 what does that mean
Mar 22, 2015 | 08:06 PM
cookingguy
How about when it's all warmed up, what's the IPR % at idle?
Mar 22, 2015 | 08:11 PM
CPB1
I will post that tomorrow morning once I get to work a 20 mile drive should get her all warmed up
Smokin.6.0
Oct 31, 2017 09:11 AM
Bri...111
Dec 21, 2015 09:41 PM
LDP
Jun 22, 2012 03:50 PM
dirtleg
Nov 6, 2010 02:05 PM
krustytheclown24
Oct 7, 2010 06:48 PM
