I need wider mirrors
Old Mar 25, 2015 | 06:34 PM
  #31
System's Avatar
System
Prolocutor
Dodge boys would be jealous!
Old Mar 25, 2015 | 06:37 PM
  #32
BigBlueOx's Avatar
BigBlueOx
Hah!!! You're right!
I won't be buying those then.
Old Mar 26, 2015 | 11:15 AM
  #33
roadkingfl's Avatar
roadkingfl
Old Mar 26, 2015 | 11:19 AM
  #34
System's Avatar
System
Prolocutor
I used the JR ones on my wife's Durango when she used to tow our boat which had an 8.5' beam. They were the only stable add on mirrors I've ever used.
Old Mar 26, 2015 | 11:42 AM
  #35
porthole's Avatar
porthole
Originally Posted by ruschejj
I'll go check, but can our mirrors be pushed a little further forward? Right now they are angled back just a bit I think. If you can push the housing an inch forward it will change the angle and by adjusting the mirror back to you it might give you wider sight line?
"position detents"
Old Mar 26, 2015 | 10:05 PM
  #36
Chad149's Avatar
Chad149
Somebody over at JR Products must be a Ford guy with a sense of humor, photos demonstrated their mirror on a Ram truck with factory towing mirrors.....
Old Mar 27, 2015 | 05:59 PM
  #37
ruschejj's Avatar
ruschejj
Originally Posted by porthole
"position detents"
Ya, I got my mirrors to hit 90° angle from the window but I don't think they'd stay there while driving fast.
Old Mar 28, 2015 | 06:47 AM
  #38
BigBlueOx's Avatar
BigBlueOx
Thanks for your help.
I'm not a fan of aftermarket add-on mirrors. When I get time I'm going to pull a mirror off and see if I can modify it to start at the fully extended position and extend the same amount as it does now.
I'm sure I can do it. My only concern is that the plastic sleeve that covers the arms wont be long enough to keep from seeing steel parts inside the arms after I modify it...Which I also don't want. I'm hoping I can shift the arms or maybe buy luck they will just barley be long enough to keep things covered.
Old Mar 29, 2015 | 06:02 AM
  #39
Rattler1's Avatar
Rattler1
I took notice of some if the mirror set ups on the larger trucks. They seem to have a block off plate on the front where the regular mirrors go and then the mirror is mounted right on the door skin. Not sure if this is something that you would be interested in or not.
Old Mar 29, 2015 | 07:57 AM
  #40
ruschejj's Avatar
ruschejj
Honestly, it would probably be less expensive and more effective to install two or four little cameras in the right spots and have a display in the cab while you are driving.
Go to an Rv dealer and check out the camera set ups on the newer motor homes for ideas.
Old Mar 29, 2015 | 03:36 PM
  #41
Amsurf's Avatar
Amsurf
I have a 2015 F350 and tow a Cyclone 5th wheel that is 44' long and I can see down the sides okay but the gap behind me where cars become visible is quite large. I'm just going to bite the bullet, buy a wireless camera and mount it above the ramp door. Since I can't use the review mirror I'm going to get a monitor that clamps on the mirror.
Also I agree with the earlier comments on the headlights, disappointing. They pale in comparison the the lights on my wife's 2013 Camry. The high beams on that car are amazing!
Old Mar 29, 2015 | 04:19 PM
  #42
BigBlueOx's Avatar
BigBlueOx
You're probably right. The only thing is, I don't have just one trailer that I haul.
Originally Posted by Amsurf
...I can see down the sides okay but the gap behind me where cars become visible is quite large.
This hit the nail on the head. It's not that I cat see at all. It's that the blind area bihind the trailer is very large. I'll have to do some math to figure just how close I can't see behind my trailers.
Old Mar 30, 2015 | 02:07 AM
  #43
SultanGris's Avatar
SultanGris
I have a 13 and my headlights are very bright, when I'm in the country using brights I get flashed to dim them from 2 miles away regularly, I can see very well. Can't imagine anyone complaining about them being dim. Maybe they have theirs adjusted incorrectly, lol
jasonodsky
Sep 29, 2011 12:07 PM
Seven-Point-Three
18
Apr 9, 2010 05:47 PM
fordtruckman
2004 - 2008 F150
Jun 3, 2007 10:49 PM
WildTurkeycj8
Apr 17, 2005 04:00 PM
Scott_XLT
Jan 10, 2005 02:39 PM
