E4OD Trans was acting up, JERK shift ?
Old Mar 19, 2015 | 04:06 PM
Realslowww's Avatar
Realslowww
Today my 1994 E4OD tranny started shifting real hard and Jerky but then I fiddled with the fuses in the box inside the cab and the rest of the day it shifted right. I do not understand what the trans was telling me.
I have read about this in the past, any help would be great. I had the cab over head light short problem last year that was messing with the shifting but fixed that with help from this site.
Thanks.
Old Mar 20, 2015 | 12:15 PM
ConstantProject's Avatar
ConstantProject
Since fiddling with the fuses "fixed" the problem, maybe a loose wire or corrosion? If the problem is gone it will be hard to do a permanent fix and you run the risk of creating another problem. I would at least try removing and cleaning the connections from any dirt, dust, rust, or grime that might cause a faulty connection.
Old Mar 20, 2015 | 01:03 PM
Realslowww's Avatar
Realslowww
Thanks, I am not sure what it was but it went away. I am thinking about trying to find a old school C6 3/4 ton truck in good shape. I like my 94 IDI turbo but I like less complicated as well. Maybe a 5 speed ?
Old Mar 20, 2015 | 02:28 PM
ConstantProject
Late last year I bought a 94 f350 idi turbo auto, dually my first diesel, but not my first old car so I have a list of things to do to it before I daily it. Engone and transmission work perfectly, I replaced all the braking system with exception of booster and master cylinder which I just ordered. If you like standard go for it, I will keep the auto as long as I can just for the commodity.
Old Mar 20, 2015 | 03:32 PM
Realslowww's Avatar
Realslowww
I like this truck to but my most reliable no hassle truck I ever owned was a 3/4 ton c6 300 I6 CARB model. Nothing ever kept it from just going.
relentlessmx
Dec 20, 2008 02:14 PM
bung
Nov 17, 2004 02:10 PM
butch a 250 d
Mar 31, 2004 09:08 PM
GJStriker
Feb 15, 2004 01:13 AM
