A/C is basically always on, what the hell?
Old May 3, 2007 | 09:40 AM
CentralCoaster's Avatar
CentralCoaster
I hate the automatic climate control in this thing.
So last night it was about 60F and it was somewhat cool inside my truck, windows down, in the echoey drivethru, I turned my climate control on at 75F several times. The A/C compressor clutch cycled on every time.
Is there an explanation for this, or are the Ford engineers just stupid? It should be calling for heat, not A/C. The truck was warmed up too. Unless it's acting as a reversing heat pump or something bizarre like that that. Based on my HVAC controls experience, I suspect the former to be the case.
I find myself turning it on and hitting 10 buttons just to get it set to where I want in manual mode in heat or vent. I don't want my A/C running all the time, gas mileage is bad enough.
Old May 3, 2007 | 09:59 AM
KevinM's Avatar
KevinM
Your climate control cycles between heat and AC to keep the set point at the setpoint.. It's much more accurate since you dial in the temp you want. If you had the hot to cold temp setting type it is just not as accurate.
BTW be glad it does it, the AC cycling will keep the humidity down and prevent window fog!
This is common on all makes of climate control systems.
Old May 3, 2007 | 10:08 AM
screwy's Avatar
screwy
Yep, it’s humidity control. I think they should include a humidity sensor to better regulate this with these fancy electronic controls, but that cost money. I think they should have incorporated away to manually control the temp too basically exactly like manual controls. I have a tendency in winter to drive around with the window down and heat on full blast, but this thing just gets confused and constantly changes temperature.
Old May 3, 2007 | 10:11 AM
lrappl's Avatar
lrappl
Yep...that's how it works. I have automatice climate control on my Mazda 6. I ALWAYS put it in manual mode. I specifically did not get the ACC on my truck because of my experience with it in the Mazda.
Old May 3, 2007 | 03:33 PM
CentralCoaster
Thanks for the info.
Here in CA, controls like that are banned in residential and commercial HVAC because of the waste of energy, but it should be capable of keeping a tight temperature.
Yet it fails to do that. Seems as if the temp feedback sensor is in a crappy spot, it should be in the driver's headrest or something.
If you want heat fast getting in on a cold day, you have to use the vent mode and point the ducts at you, instead of waiting for it to heat it from the floor up. Then when you get in after work and it calls for a/c, the fan roars up trying to cool it off quickly and lifts the eyelids off your eyeballs.
My 69 and 85 cars with manual heat/ac keep me much more comfortable and are faster/easier to use.
Old May 3, 2007 | 11:40 PM
the4by4freek's Avatar
the4by4freek
All Ford vehicles from about 85-present run the AC clutch in AC, DEF, and some of the vent modes. Ranger, Taurus, Expedition, F-Series... ect. It doesn't matter if it's ECT or manual, it still runs. I kind of like mine... all I have to do is bump the temp 2 deg either way to be comfortable. If it's too cold then 2 deg will shut it down. If it's too hot 2 deg will cool it off. If I have the windows open then the climate control is off. That just makes sense
Old May 5, 2007 | 02:57 PM
BlueRidge's Avatar
BlueRidge
Coaster,
When I bought my Lariat I complained about this to the salesman. They showed me that if you select one on the vent functions instead of Auto then adjust the temp settings (do not touch the fan speed) it works the same way without running the AC. It even automatically speeds up and slows the fan like the auto button. If you select a vent setting then chose a fan speed that disables the auto function and goes to manual. Try it.
Old Dec 25, 2007 | 09:20 PM
Mystic_Cobra's Avatar
Mystic_Cobra
Anyone know how easy a swap would be with the auto climate control from a lariat into my 05 FX4? Could I just swap the dash control or would I need to swap more parts?
Old Dec 25, 2007 | 09:28 PM
osbornk's Avatar
osbornk
Originally Posted by BlueRidge
Coaster,
It works exactly the same way in my Town Car. You can tell the difference because when you have in on floor outlets, you can tell the AC compressor is not on because the windows will fog and when you switch to automatic, everything seems to stay the same except the windows defog. Took me 2 years to figure that out on my own. I should have read the book. I like automatic temperature control (especially after I learned how to use it). I wish I could have gotten it on my XLT.
Old Dec 25, 2007 | 10:58 PM
lsrx101's Avatar
lsrx101
One thing to remember about having the compressor running in the winter is that the extra fuel usage is minimal. With the CCOT AC system, the system pressures drop with the temperature as does the actual on-time of the compressor. Below about 40 degrees, the sompressor rarely engages.
Many folks disconnect the compressor clutch thinking that they will save fuel. The bit of extra time spent in open loop on cold days easily overshadows any savings from disabling the compressor. At low temps, the AC system just isn't working very hard at all because it's removing very little heat.
Old Dec 26, 2007 | 10:51 AM
osbornk's Avatar
osbornk
Also, the AC compressor running occasionally is good for it. It prevents the seals from drying out and leaking.
Old Dec 26, 2007 | 12:39 PM
lsrx101's Avatar
lsrx101
You would need the complete system from a donor. I suspect there are wiring differences in the main dash harness, but with the right parts it "may" be plug and play. It would be much more than swapping the controls though.
Old Dec 26, 2007 | 07:56 PM
Mystic_Cobra
I don't like the idea THAT much. I was hoping that they maybe used the same wiring harness/heater box for both trim levels.
Old Dec 26, 2007 | 08:17 PM
lsrx101's Avatar
lsrx101
I understand that. EATC is really nice. The swap would definately be the controls and the "suitcase" behind the dash plus a couple of sensors. That's the easy part. The "gotcha" might be in the dash harness. Sometimes accessory wiring is pre-fit into the main harness, sometimes not.
Old Dec 26, 2007 | 09:33 PM
Mystic_Cobra
I think I'll just get a Lariat next time.
thanks.
