Starter?
Old Mar 17, 2015 | 09:42 PM
thesheff0718's Avatar
thesheff0718
Starter?
My 69 F100 wont start, just ticks once tried to jump it and still just does the one long tick. Went and replaced the starter solenoid because thats where the sounds coming from and its still doing the same thing. Any ideas on the next step to getting this thing running again?
Thanks
Old Mar 17, 2015 | 10:09 PM
351Cleveland C4's Avatar
351Cleveland C4
Get the starter off and have it tested.
Old Mar 17, 2015 | 10:28 PM
51M1's Avatar
51M1
Also check your battery cables. The cable from the solonoid to starter can internally corrode. Just throwing in ideas...
Old Mar 17, 2015 | 10:40 PM
thesheff0718
Thank you ill work on these tomorrow.
Old Mar 18, 2015 | 03:47 AM
Mister_King's Avatar
Mister_King
I had my starter tick on me.
Ended up being a bad ground.
I was 5 minutes away from buying a new starter until I noticed the ground.
It's been 3 months and it still starts perfectly fine.
Good luck.
Old Mar 18, 2015 | 09:34 AM
qman's Avatar
qman
Step 1 (simplest). Make sure all electrical connections between battery and ground and starter are clean. (this means disconnecting them and taking a wire brush to them.)
Step 2 (next simplest). Make sure where your starter makes contact with the engine block is clean and the bolts are tight.
Step 2 (hardest part). Take your starter and have it tested.
Old Mar 19, 2015 | 05:45 PM
thesheff0718
Went and got the battery tested. It was a bad battery put the new battery back in and started right up. Thanks yall.
Stonesetter1
May 29, 2015 02:31 PM
mac01
24
Nov 27, 2009 03:01 AM
StrongRepublican
22
Feb 19, 2007 02:20 PM
Buggie
Feb 9, 2006 08:47 AM
gordo350
Nov 19, 2004 06:22 PM
