e4od problems help!
Old Mar 16, 2015 | 09:23 PM
bluethundersowner's Avatar
bluethundersowner
e4od problems help!
I have a 97 with a ts chip and e4od trans. My trans began slipping and I had it built by a local guy. Triple disk converter and suncoast internals. Sometimes when I'm on the highway and go over quarter throttle the overdrive light will start flashing and it shows a p1728 transmission slip fault code. The thing is the transmission isn't slipping. I'm wondering if I have to get my chip retuned for having the triple disk converter? When the light is flashing the converter stays locked when I try to stop. Once I give it a little throttle it will unlock. If the lights flashing and I go into reverse sometimes the converter locks and the truck stalls. If I drive the truck with less than 1/4 throttle it doesn't act up.
Old Mar 16, 2015 | 09:27 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The transmission IS slipping. It only has to slip 50 RPM to set the code. You can't feel a 50 RPM slip.
Old Mar 16, 2015 | 09:28 PM
fordpride's Avatar
fordpride
I don't think it would be the chip but you could pull it and see if it stops. Sounds like a bad converter to me but I'm not a tranny expert.
Mark will chin in soon I'm sure
Old Mar 17, 2015 | 08:19 PM
bluethundersowner
If it is slipping than how can I fix it? It does it in every tune if I go over quarter throttle.
Old Mar 18, 2015 | 07:38 AM
fordpride's Avatar
fordpride
Have you pulled the chip to see if it stops ?
Old Mar 18, 2015 | 08:36 AM
Mark Kovalsky
The first thing to do is to remove the chip and see if it stops. If it does then the chip is the problem.
If not, remove the access plate to the bellhousing. Look at the front face of the torque converter. If the steel is discolored from heat then the torque converter has failed and needs to be replaced. If not, then it is an internal transmission failure.
Old Mar 19, 2015 | 08:53 PM
bluethundersowner
Is the chip plugged in behind the parking brake pedal assembly?
Old Mar 19, 2015 | 08:56 PM
bluethundersowner
The thing is that even when a code isn't being thrown, it won't go into overdrive when it should. It doesn't go in until my temp gauge is up to 120+. And also right around there it drives like **** because it goes through the first 2 shifts fine but the lock up goes in too soon and the truck bogs and then it goes into overdrive right after. It really bogs down then.
Old Mar 19, 2015 | 10:36 PM
fordpride's Avatar
fordpride
Yes.
Take keys out of ignition
Remove parking brake assembly
Reach in hole and pull chip
we287gn
17
Mar 13, 2019 12:54 PM
kc0stp
Feb 16, 2014 03:25 AM
quesey
Aug 30, 2012 07:16 PM
rma714
Jul 10, 2010 05:57 PM
90f150302
22
Jun 10, 2010 07:43 PM
