Sponsored by: Real Truck
spark plug removal prep
Old Mar 24, 2015 | 04:59 PM
17 Oaks's Avatar
17 Oaks
Originally Posted by Gangly
Ford recommends spraying their Motorcraft Carburetor Tune-Up Cleaner after breaking the sparkplugs loose 1/4 to 1/8 turn. Like most carb. cleaners, I assume its a simple carbon deposit remover but I could be wrong. I wouldn't hesitate to use something other than motorcraft, I believe most carb cleaners are the same and probably perform similarly.
I know when I checked the following day I still had carb cleaner in the spark plug orifices on a few of the plugs. Temps were in the 50's over night for what its worth.
I am going to assume this is similar to a cleaner I used to buy at my Chevy dealer. It was used to unstick exhaust manifold heat risers. It dissolved carbon like nothing I have ever seen since and it also provided a degree of lubrication.
If so, squirt some on the plugs, go to lunch and come back and the carbon will be gone...its a miracle worker for sure...
powerstroker100
May 11, 2016 06:27 PM
TexasLonghorn75
2004 - 2008 F150
Nov 26, 2013 12:18 AM
makuloco2000
Nov 20, 2013 08:43 PM
F350-6
Jan 12, 2013 09:17 PM
67f100
Aug 18, 2009 05:03 PM
