Sponsored by: Real Truck
Speed sensor leaking
Old Mar 16, 2015 | 10:58 AM
badger2196's Avatar
badger2196
I just replaced the speed sensor on the top of the rear differential, which fixed the speedo, ABS and cruise control issue. However, there is now a ton of oil all over the differential, which I can only assume is leaking out through the speed sensor (haven't crawled under there yet). I didn't see any seal on this sensor, and it is torqued down correctly - any ideas what would cause this thing to leak?
Old Mar 16, 2015 | 11:31 AM
redford's Avatar
redford
FTE Leadership Emeritus
Is the vent plugged? Are your axle seals leaking also?
Old Mar 16, 2015 | 12:32 PM
Zedrive's Avatar
Zedrive
Was there an O-ring on the new sensor?
Was there one on the old sensor?
I think your missing an O-ring.
Old Mar 16, 2015 | 04:17 PM
badger2196's Avatar
badger2196
I didn't notice an o-ring on the old sensor, and the new one didn't come with one.
Old Mar 16, 2015 | 05:10 PM
Lou Braun's Avatar
Lou Braun
The Ford rear speed sensor (PN 6L3Z9E731A) does come with an o-ring installed. The o-ring is not listed separately though.
If you still have your old sensor, just match up the o-ring with one from an o-ring kit.
Lou Braun
LTCPipkin
Aerostar
23
Dec 4, 2008 01:21 AM
Mormakil
Aerostar
Mar 29, 2006 05:13 PM
nanufree
Dec 19, 2005 12:33 PM
bbor62
1983 - 2012 Ranger & B-Series
Jun 21, 2004 11:22 PM
dheffley
Jul 27, 2003 05:09 PM
