I am looking to buy a tool to help me make the job of bleeding brakes a more enjoyable and quicker experience. I have been looking at one of those Mityvac pistol type suction devices. I also have seen those devices that push brake fluid through the lines via pressurization. It seems the Mityvac is able to be used for my things than just bleeding brakes. This appeals to me as I really would like my tools to be as multi-task friendly as I can get them. Has anyone used one of the Mityvacs for bleeding brakes? Are they worth the money and which one is worth getting?
Yes, they're worth it, but you have to make sure you get one WITH the vacuum gauge on it. The one that's sold as a "brake bleeding kit" only does NOT have the gauge, but the normal $30-40 kit has all the bleeding stuff with it. The $50 metal one is nice - I accidentally melted my plastic handle by leaving it on the engine during a test-drive.
It pulls air bubbles around the bleed valve and you can never tell when you're got a truly air-less system.
(this was when I used it on my Volvos)
It is, however, useful as a vacuum gauge for timing advance, or other vacuum related aspects of shadetree mechanics.
The pressurized 'pushers' work much more reliably, if you ask me.
you just got to make sure you have a way to keep adding brake fluid.
The best (and cheapest) way to change brake fluid is to have your girlfriend step on the pedal while you top up and bleed.
BUT, I didn't like the Mityvac brake bleeding.. I even installed teflon tape around the bleed taps to seal the air out better, and still couldn't get a good indication.
Hi,
I also have the Mityvac and have used it in the past for bleeding brakes and I to was not happy (I usally use the soda bottle and hose method with excellant results)
The advantage is that the Mityvac can be used for numerous other things like checking vacuum servos and emptying power steering pumps etc.
I would also recommend one with a gauge, didn't know they also made them out of metal
Thanks guys. I am reading about mixed emotions concerning these tools I am looking to buy a used one so for a bargain I guess it is worth it. I do think I am going to have get one of those pusher type pressurizers for the brakes. I just wish I could make one cheap from a garden spayer. Any hints how that might be done?
There are topics in the Garage and Workshop forum on this subject. We have all kinds of tool questions there. There are directions for making pressure bleeders also.
I use a Mity-Vac for bleeding my brakes. Mine has the gage. I have found that the problem with pulling air past the bleeder threads is a function of how much vacuum you apply. In other words the tool works well if you don't try to get in a hurry!
