EGT's idling
Old Mar 15, 2015 | 07:55 AM
endobear's Avatar
endobear
EGT's idling
Im getting 230-250 degrees idling on a warm motor. What is the average everybody else sees?
Old Mar 15, 2015 | 08:00 AM
timmyboy76's Avatar
timmyboy76
i havnt paid much attention, since if motors warm, i just get in n go. Idling TO warm up, i see 100-150ish on both gauges, p/s being the tad hotter
Old Mar 15, 2015 | 08:01 AM
roostercrows's Avatar
roostercrows
I think I'm in the 280s range....
I'll double check and post back.
Old Mar 15, 2015 | 08:18 AM
endobear's Avatar
endobear
Ill check her cold.
Old Mar 15, 2015 | 08:20 AM
endobear's Avatar
endobear
That would be great. Thanks
Old Mar 15, 2015 | 08:34 AM
mueckster's Avatar
mueckster
You will probably get a variety of answers for this. Ambient temperature, and that of the a/c condenser & trans cooler, can affect the I/C temp thus affecting idle EGT. I, generally, saw 250-300* after all the temps stabilized.
Old Mar 15, 2015 | 08:38 AM
white Buffalo's Avatar
white Buffalo
Idle speed (rpm's) will affect it as well.
Old Mar 15, 2015 | 10:15 AM
Tugly's Avatar
Tugly
It varies with the temp, altitude, and planet alignment - I've seen 200 - 400 degrees on both EGT gauges with the sensors located on the manifold exits.
Old Mar 15, 2015 | 05:27 PM
JOHN2001's Avatar
JOHN2001
I seen 800 at an idle and took 5-10 minutes to drop back down to to the normal 250-400
Old Mar 16, 2015 | 02:36 PM
endobear's Avatar
endobear
It appears my EGTs are all over the place at idle. Which sounds about what everyone else is seeing. I never paid attention to them at idle until right before I pulled the turbo to do some work. I thought after turbo work it had dropped from around 330 too 240ish. Ive been seeing anywhere from 240-300 .
olfordsnstone
Oct 23, 2016 11:15 AM
BlackBeest
6.7L Power Stroke Diesel
Jan 20, 2015 06:30 PM
KonaGrown
49
Apr 1, 2009 10:18 PM
Bill W
Arizona Chapter
Dec 29, 2007 05:46 PM
hirschdale350
Feb 7, 2006 12:02 AM
