Connector c126
Old Mar 14, 2015 | 10:18 PM
wtroger's Avatar
wtroger
Connector c126
1991 Ranger 3.0 distributor connector. FSM says it is coneector c126. Would like the pin outs of that connector. For some reason it isn't in the FSM. I have searched and googled and cant find anything.
Old Mar 15, 2015 | 06:18 PM
pawpaw's Avatar
pawpaw
Are you trying to discern the pinout to the distributor mounted ignition control module???? http://easyautodiagnostics.com/ford/...module-tests-2
Old Mar 15, 2015 | 08:41 PM
wtroger's Avatar
wtroger
This distributor doesn't have the module mounted on it. It has a 4 pin connector. That is c126 on all the diagrams I have seen. Yet It looks like Ford doesn't want to show this connectors face and pin outs
Old Mar 15, 2015 | 11:47 PM
pawpaw's Avatar
pawpaw
Ok, so no icm mounted on the distributor. I don't have anything older than my 94 Taurus that has a distributor, so my paperwork isn't gonna be worth a flip. I'll poke around the net & see what I can find too.
Old Mar 16, 2015 | 12:05 AM
pawpaw's Avatar
pawpaw
How about this Autozone wiring pictorial that says its for a 91 3.0L http://repairguide.autozone.com/znet...3f8021195f.gif
Old Mar 16, 2015 | 11:42 PM
wtroger's Avatar
wtroger
Pawpaw thanks for the link but once again that one is for distributor mounted icm not remote. What I am trying to do is bench test a used distributor before installation. I found one picture. And compared it to the FSM wiring diagram. Then using a power supply and my very old sun machine o-scope I was able to see the Hall effect signature. So I will try this distributor.
Old Mar 17, 2015 | 08:54 AM
pawpaw's Avatar
pawpaw
Good idea to rig a bench test of the hall effect pickup trigger pulse to the remote ICM before installing the distributor. Good to hear you got it sorted out & tested.
THE BLUE HEAP
Jun 8, 2016 05:59 PM
locknkey
Mar 2, 2013 08:02 PM
bpete
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 6, 2011 09:32 AM
blu
Aug 6, 2003 07:55 AM
mike dalton
Apr 11, 2001 08:22 AM
