Spout connector
Old Apr 9, 2001 | 09:05 PM
mike dalton's Avatar
mike dalton
Spout connector
I hate aftermarket manual. 1995 Ford F-150 5.8l. Put in distributor, pulled the connection next to the coil near back of engine and set timing at 10. Only problem is i am not sure the connection I pulled is the right one. I do not have tfi but believe this unit is a Dura Spark 2? No vacumn advance on distributor but does have flat spot where one would mount. Only one plug to dstributor. Can anyone tell me if I pulle the right thing?
Old Apr 9, 2001 | 09:43 PM
PAUL_2's Avatar
PAUL_2
Spout connector
If the engine & distributor is the trucks original then it has a TFI Module . The Spout Connector is two wires , about 5 or 6 inches long capped off with a square plastic piece coming out of the bottom of the distributor , you remove that cap & adjust the timing . Reinstall it when you have finished .
Old Apr 10, 2001 | 04:37 PM
StrangeRanger's Avatar
StrangeRanger
Spout connector
Not sure about your 95, but on a 96 the SPOUT connector is atop the driver's side front wheelwell between the air box and the ignition control module.
Old Apr 11, 2001 | 08:22 AM
Pastmaster's Avatar
Pastmaster
Spout connector
