ignition module pin #1?
Old Aug 2, 2003 | 01:22 PM
blu's Avatar
blu
Which is pin #1?
Is it the closet to the top of distributor or the closest to the base?
When debugging a no-spark condition - chiltons manual says connect (-) terminal voltmeter to distributor base and (+) terminal voltmeter to connector #1 on TFI harness.
The electrial schematic does not point out which wire is pin#1, nor does the connector , chiltons or the module have reference marks for pin #1.
Thanks
Old Aug 2, 2003 | 02:12 PM
90f150moneypit's Avatar
90f150moneypit
Starting from the top down.
Old Aug 6, 2003 | 07:55 AM
blu's Avatar
blu
Haynes manual came in the mail yesterday/last night.
Pin #1 is closest to the base of the distributor.
Voltage checks that Chiltons online specifys for pins 1,2,3 are from the bottom up.
