Gotta love carpet dye.
looking good !
i have always found that removing the carpet and giving it a good bath in the tub was a relatively easy and cheap way to spruce up an old vehicle, but i had never considered the possibility of dying it; thanks for the tip !
is carpet dye something that the average parts store is going to have in stock ?
I used a chrome wheel cleaner. It was spoke wheel cleaner from AutoMagic (the brand a lot of detail shops use) Used it for years on pontoons when I ran a service department at a boat dealer. Just wear gloves, it will burn your skin. Helps to take a scotch brite pad and scrub it in. Just don't let it dry on the wheel, makes a mess. Be very liberal with it and make sure the wheel is covered completely. I bought a gallon but probably only used a 1/3 of it if that. Sprayed it on with a regular spray bottle.
looking good !
I like buying it from the little store cause they will let me take a can out and test the color. Plus they have a lot of colors. The color looks different on carpet than it does vinyl, if you choose to dye any seats or the dash.
If you don't put floor mats down it will wear out over time. Just remember what color you used.
If you are covering any major stains you will need to go a few shades darker for the best appearance.
Good luck!
SmokeyBear31
33
08-01-2016 04:42 PM
