What do ya do when you're here ?
Old Mar 15, 2015 | 03:48 PM
Pikachu's Avatar
Pikachu
I went through a ton of quarters when I had my intercooler and radiator out of the truck and took them to the car wash. The fins hold a ridiculous amount of road dirt.
Old Mar 15, 2015 | 04:24 PM
Bill Kay's Avatar
Bill Kay
I used a hot water pressure washer (we call it a hotsie) thru mine and holy cow do the condenser and radiator hold a lot of crap.
Not to hi-jack but I just replaced my waterpump and soon after the belt started squeaking. What is the best way to determine where it is coming from. I can feel no lateral movement in any of the pullies.
Old Mar 15, 2015 | 06:07 PM
250 STROKER's Avatar
250 STROKER
The reason I`m replaceing the w/pump pully is because I here a squeal when the fan is locked-up and I`m on the trottle it looks bright and glazed I`ll let you know.
Old Mar 15, 2015 | 09:42 PM
AllaboutMPG's Avatar
AllaboutMPG
You may want to check your tensioner. Mine was worn to the point that much of the spring tension was gone and I had a constant belt squeak. Tried a new belt and seemed ok for a short time till the belt got broke in / stretched a little then squeak started again. Repalced tensioner and all is well.
Old Mar 16, 2015 | 08:58 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Originally Posted by Pikachu
What would we do about what at this point? Personally, I'd probably have a beer.
Right on!
Also, what about replacing the water pump? I mean you're right there...
Old Mar 16, 2015 | 07:38 PM
250 STROKER
Originally Posted by SDElwood
Right on!
SD I replaced the waterpump @ 244K went to ELC I`m now @ 290K I hope I have 50K more on this one ( NAPA PUMP ) who nose.
Old Mar 17, 2015 | 08:50 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Ah, ten-four. Just checking. I've got well over 100k on my Napa water pump, it's been a really good part! ... wait, maybe I shouldn't have said anything about that....
Old Mar 17, 2015 | 08:54 PM
petrokiller's Avatar
petrokiller
Put a spray nozzle on your garden hose that adjust to stream. If your water pressure is good just blast from engine side toward yourself.
if heavily gunked up soak fins with simple green the flush.
Ferguson65
All Things Towing
Oct 10, 2015 07:24 PM
adamkat22
May 5, 2014 06:26 AM
P7M8
Jun 23, 2012 07:33 AM
KelVarnson
Aug 12, 2007 12:05 AM
gungho351
Apr 28, 2006 03:47 PM
