2000 EXcursion Ignition Problem
Old Mar 14, 2015 | 02:42 PM
ironweld361's Avatar
ironweld361
Thumbs down 2000 EXcursion Ignition Problem
anyone have problems with Ignition switch going to Acc. even with the key removed and the steering locked???
Old Mar 14, 2015 | 08:18 PM
Drunken_Unicorn's Avatar
Drunken_Unicorn
Is it turning into acc. when the key is pulled out? Or, is the acc. still on when you pull your key?
Old Mar 15, 2015 | 02:19 PM
ironweld361
your Q
Thanx for the reply. Yes the acc. are on in the key OFF position, even more spooky, the radio speaker output can be heard in park and neutral only. the blower motor continues to run also even with key removed. Igot a replacement ignition switch , will install this afternoon
Old Mar 15, 2015 | 02:50 PM
Drunken_Unicorn
Have you installed a stereo recently?
RBerry9511
Feb 7, 2020 04:31 PM
99psdggw
May 28, 2015 07:35 PM
raineytx
Nov 22, 2005 11:54 AM
johnlynn
Dec 27, 2003 10:17 PM
