turbo torque specs
Old Mar 14, 2015 | 11:39 AM
Blapensee's Avatar
Blapensee
turbo torque specs
anyone know what the specs are bolting the turbo to the pedestal? h&s says from the pedestal to the top of the motor is 35ftlbs does that sound right? the 3 bolts holding the turbo to the pedestal are internal so i need to get it right the first time.
Old Mar 14, 2015 | 09:41 PM
Blapensee's Avatar
Blapensee
incase anyone cares i found out its whatever the bolt is rated for by its size. in this case its an M8x70mm which is about 18-20lb*ft
Old Mar 15, 2015 | 07:17 AM
ruschejj's Avatar
ruschejj
I would have suggested the very same. The medical equip I assemble uses M hardware and the M8 is pretty standard and the torque value is lighter than we would like to think.
I did not comment because I didn't know the official ford spec. But yea, for regular stuff I think generic torque charts are pretty safe. The M10's I use for work are about 36ft-lbs.
Old Aug 11, 2020 | 05:25 PM
565bbc's Avatar
565bbc
I know it's an old thread but Thank you for that info.
Old Sep 26, 2022 | 03:11 PM
ANTIGOVERN1's Avatar
ANTIGOVERN1
3rd Gear
dry vs wet torque
qty 8 - 8mm grade 10.9 torque all to 18 lb/ft
qty 2-10mm grade 10.9 torque to 35-42 lb/ft
dieselbronc
Mar 4, 2021 10:10 PM
pilgrimbizket
Apr 27, 2019 11:04 AM
dmm50
Sep 10, 2012 08:19 PM
midcal48
Sep 30, 2011 11:18 AM
johnsjsj
Sep 17, 2010 06:35 AM
