7.3 powerstroke turbo torque specs
My rebuild kit for my turbo from Clay should be here tommorrow, I cant seem to find the torque specs for the Pedistal bolts/2 turbo bolts/all 5/16"12 point turbo housing bolts-steel housing and aluminum housing.If anybody has these I would greatly appreceate it.
The pedestal bolts are 18 ft lbs. Ford says the two turbo bolts are 18 ft lbs too. Garrett says the torque specs are 35 ft lbs.
18 seems to work fine on the pedestal, although I usually snug it a little past that. I've always used the garrett spec of 35 on the turbo and never had a problem with it.
Take a look at his OBS rebuild instructions. The torque specs are in there too. Bolts are pretty much the same for both.
http://www.riffraffdiesel.com/mm5/RE...bo_Rebuild.pdf
