Destributor timing
Old Mar 13, 2015 | 06:52 PM
Oakroadjoe's Avatar
Oakroadjoe
Destributor timing
Got my 226 rebuild started today but cant time it. The dist.is at the end of its travel and i am off(btdc) several degrees. How do i get it corrected?
Old Mar 13, 2015 | 07:11 PM
Tedster9's Avatar
Tedster9
Sounds a lot like the distributor is "off a tooth". Remove and reinstall with the rotor leading the #1 tower a little more. The helical gear on the distributor gear causes this. If you bring the #1 cylinder to TDC and see where it points now you'll get the idea. Sometimes it's kind of a bear to get everything lined up and drop in right.
Old Mar 13, 2015 | 07:26 PM
Oakroadjoe's Avatar
Oakroadjoe
Thank you i will try. It sounds right.
Jhardy62026
Oct 12, 2017 12:53 PM
backbonejay
Apr 12, 2013 04:31 PM
rostronic
Mar 6, 2012 10:17 PM
ErrorS
Oct 16, 2007 12:41 AM
jpavlice
Sep 15, 2003 07:47 PM
