Sponsored by: Real Truck
Chains/Binders for Towing
Old Mar 13, 2015 | 05:11 PM
SMLWinds's Avatar
SMLWinds
I am going to be towing with my new F-350. I have towed cargo and landscape trailers but now that I have my new truck, will be doing some heavier towing. I will be towing my 11K pound excavator, a skid steer, and several antique tractors.
I am new to chains and binders--what do you guys recommend? I want the best ones available so even if they are pricey, let me know. How strong do the chains need to be? (the largest item is the 11K pound excavator)
Any recommendations on specific chains, sizes, and binders is greatly appreciated!
Old Mar 13, 2015 | 05:25 PM
seville009's Avatar
seville009
I would just used the highest rated binders you can without going overboard. That what I did when getting binders/chains - my heaviest equipment is about 8,000 lbs of skidsteer. Better safe than sorry.
Old Mar 13, 2015 | 07:39 PM
sgarder's Avatar
sgarder
Your best bet to be legal is to look up FMCSA website. The DOT has their rules that need to be followed to keep you from getting a hefty fine. Be prepared to read and reread to comprehend. I think tie down chains need to be a different color? It doesn't matter if it is private or commercial, with an excavator the scale, and DOT will assume commercial, and treat you as such. I think the chain has to be gold colored.
Old Mar 13, 2015 | 08:27 PM
Mr. Mcbeevee's Avatar
Mr. Mcbeevee
Correct on the chain color. Dot approved chain will be gold colored and priced higher than your standard log chain. On binders I have always liked the cam binder style combined with a 3ft pipe for leverage over the turnbuckle style. Just remember to hook them so you are pulling down to tighten them , not pushing up. You will loose some teeth eventually if you don't. Always put your binders on the drivers side so they are easier to check on your rear view while going down the rd.
Old Mar 13, 2015 | 09:01 PM
Mtncrash1's Avatar
Mtncrash1
Cross chain anything on tracks and, save the teeth and other parts of your body. Use a ratcheting type binder.
Old Mar 13, 2015 | 10:24 PM
SMLWinds's Avatar
SMLWinds
Can you guys post some links to whatever you recommend? I would like to study this options and learn more about what is best.
So, sounds like I need gold chains. As far as strength goes, I'm all for overkilling the strength of the chains and binders...how strong do the chains get? What rating should I be looking for to be in the strongest class? Should each chain be rated to hold the full weight of the cargo? In other words, if I have an 11K excavator, do I need to find chains that hold at least 11K? I haven't seen any that strong so I was wondering.
Please give me some websites for reputable, quality tow chains and binders. Thanks!
Old Mar 14, 2015 | 02:54 AM
seville009's Avatar
seville009
Go to a place like Tractor Supply
Old Mar 14, 2015 | 05:28 AM
scraprat's Avatar
scraprat
Top Answer: 5
Good point and one more thing when releasing try not to put a pipe on it and pull up. I warned a guy about this and didn't listen and took out his front teeth with the pipe from the pressure that was on the binder when released.
Old Mar 15, 2015 | 07:37 AM
BigBlueOx's Avatar
BigBlueOx
Do this^
Don't use the cam style binders. They are dangerous no matter how you use them.
Use the turnbuckle style and you can get them tight. You won't have to worry about them popping open or injuring you.
My .02
Durabilt Titan Super-Duty Ratchet Chain Binders | Truck n Tow.com
Old Mar 15, 2015 | 09:49 AM
SMLWinds's Avatar
SMLWinds
Is Tractor Supply going to have the highest quality products? I tend to stay about from the big box stores like Lowes, Home Depot, etc. because they often have more consumer grade product. If Tractor Supply has as good of quality as anyone, that does make it easier but I don't mind spending more money if there is a superior product out there. I'm definitely interested in spending the money to invest in top notch chains and binders--is Tractor Supply a place I will find that and if not, where?
Thanks!
Old Mar 15, 2015 | 01:58 PM
seville009's Avatar
seville009
They carry heavy duty stuff; it's where I got my chains snd binders. You can always go to a tractor dealer too, or heavy truck shop.
Old Mar 15, 2015 | 03:01 PM
meborder's Avatar
meborder
excellent thread:
Chain Binders?
KRDiesel
Feb 12, 2012 12:45 PM
Gundown64
2004 - 2008 F150
29
Nov 23, 2011 06:27 PM
78 Ranger
Offroad & 4x4
16
Feb 5, 2008 04:55 AM
78 Ranger
All Things Towing
Feb 2, 2008 03:11 PM
