Well I already did. Of course this means we'll maybe get three feet in a week or so, but what I'm getting at it seems there's a couple different schools of thought on preparing equipment for storage. Everybody agrees that stale fuel is a bad thing, and avoid alcohol laced fuel in two stroke engines. But some mechanics claim that the carburetors shouldn't be left dry though - keep fuel in it, use a fuel stabilizer instead. Thoughts?
if you have a needle float in carb those are ok to run dry ,,,,carbs with the paper elements are different but i ran them dry to and worked next season
We can get ethanol free straight gasoline around here but it's quite a bit more expensive. But lawnmowers and snoblowers use so little fuel it doesn't matter.
I poured the excess fuel from the snoblower into the lawnmower and it fired right up without too much trouble.
I didn't care for those, at least the small retail consumer POS versions. They leaned 'em out (or something) so they wouldn't start (or restart) very easy, "CARB" regs probably.
