Sponsored by: Auxito
Stuck Hood
Old Mar 12, 2015 | 10:26 AM
Roger Hopson's Avatar
Roger Hopson
Stuck Hood
After changing my oil in January my hood on my 2000 F 150 XLT would not latch so I had to bungie cord it closed so i could get back and forth to work. now that the weather has warmed up (thank God) my hood won't open its stuck closed. Hood release won't open it still feels like its connected thou. anyway to open from the outside?
Old Mar 12, 2015 | 11:13 AM
catbones's Avatar
catbones
sounds like the wire is there and attached but the spring is gone... any way you can take a look at it from the bottom up? happened to me too...
Old Mar 12, 2015 | 12:14 PM
Kellyblues's Avatar
Kellyblues
Spring is a possibility. Lack of lubrication could be it also. If you get a visual of the spring being in place get a can of white lithium grease and spray the tar out of the assembly . After that push down and pull up on the front edege of the hood with someone keeping the latch release pulled in the cab
Old Mar 12, 2015 | 03:55 PM
kd4gij's Avatar
kd4gij
I had that prblem. the hood strus where shot and wouldn't raize the hood from the first cath. Have some one hold the hood relise lever while you lift the hood. Then replace the struts.
Old Mar 12, 2015 | 09:39 PM
jwh's Avatar
jwh
Look through the grill at the hood latch. You should see 2 8mm bolts. Stick socket w/ extension through grill, remove bolts, hood should open far enough to disengage latch.
Old Mar 13, 2015 | 12:38 AM
davidend0's Avatar
davidend0
My hood got stuck before and it turned out the spring latch was the problem. But i wasn't careful enough, I used a bar to twist the cable, I ended up having to get a new cable and latch. Hope you get yours opened without any damage.
Raymond
Jan 17, 2024 01:41 PM
SeaCarr
Aug 18, 2015 09:58 PM
Spades
Jan 31, 2008 12:24 PM
shwagy357
1966 - 1977 Early Broncos
Mar 20, 2006 09:23 PM
