Sponsored by: Real Truck
Hood won't open
Old Nov 3, 2013 | 05:59 AM
Raymond's Avatar
Raymond
Veteran: Navy
Hood won't open
I have searched the forum and tried everything that was suggested to open the hood on my 2000 and nothing works. When looking form the front you can see the hood release operate, but nothing happens. What part of the release do I need to operate to get the hood to open? Any help or suggestion would be greatly appreciated.
Old Nov 3, 2013 | 06:46 AM
rockertom's Avatar
rockertom
Walk around to the front of the hood where the latch is. Give the hood a thump with a closed fist on the pinky side. Should pop the latch. The cables do have a tendency to stretch and not hold the latch long enough to fully release it on its own.
Old Nov 3, 2013 | 06:56 AM
seville009's Avatar
seville009
When i pull the hood release inside my truck, nothing appears to happen (there's ni pop and the hood doesn't move), but i can then go to the hood and lift it up to reach in and release the latch.
Old Nov 3, 2013 | 07:16 AM
Hotrod70d's Avatar
Hotrod70d
sounds like u need some spray grease on the latch . the cables go bad also
Old Nov 3, 2013 | 08:29 AM
seville009's Avatar
seville009
I've tried greasing it, but it didn't change anything. As long as I can get it open, that's good enough for me.
Old Nov 4, 2013 | 08:53 AM
Raymond's Avatar
Raymond
Veteran: Navy
I ended up unbolting the latch mechanism and the latch from the hood to finally open it. I cleaned and greased the mechanism and it works now.
Old Jan 17, 2024 | 09:31 AM
aubrey aubrey's Avatar
aubrey aubrey
1st Gear
It won’t open bc this is not the lever to open the hood. It’s on the top
of the hood right above the passenger headlight. It’s hard to find and hard to open, you have to push the latch up and try to open it at the same time. That yellow latch thing is NOT the latch to open the hood!
I had the same issue, couldn’t open the hood, checked online sources and had to pull out the book to figure it out. Wouldn’t you know so many people complained that they made the 07 models way easier! Crazy to pay 70k for a vehicle and the damn hood is so difficult to open!
Old Jan 17, 2024 | 01:41 PM
Split rims's Avatar
Split rims
Ten year old thread!
Gigemags05
1947 and Older Ford Trucks
Feb 15, 2019 10:00 PM
53Mercdriver
Jul 14, 2014 11:34 AM
rastenburg
Paint & Bodywork
Jul 30, 2009 09:15 AM
macian
Sep 13, 2004 09:51 AM
