My 98 Ford Expedition boggs out and the rpms rev less at 1000 and when i accelerate it does give alot power . I need help. as myfront windshield wipers don't work .I tried finding the relay fuse but its not a help. And when I drive my suspension is horrible .
I know a lot of people here want to help you out. But it's best if we concentrate on one problem at a time. That way we can get more specific for you.
That being said, I'm glad to try to help. Since the subject line is acceleration issues, let's start there. When does your vehicle bog down in rpms? While driving, or when stopped? Does it die when you step on the gas pedal?
The the acceleration issue, I want to add a couple of questions to the above post from FoxFord33. Where I like to start when facing these kinds of performance issues is with the basics:
When was the spark plugs last replaced? Last oil change? Is the oil at the correct level? Last fuel filter replacement? Is the air filter dirty? Did you clean the MAF sensor? Transmission oil color, odor and level OK?
