Help no WTS light !
Old Jan 4, 2014 | 11:10 AM
Blh4488's Avatar
Blh4488
Help no WTS light !
I bought 1999 ford f250 7.3 a week ago. Yesterday I was on my way to work ( 20-30 after starting truck) and it just died. Was running like a top before this. I've changed the glow plug relay, relay 30 in the fuse box, the fuel filter, tried unplugging the fuel heater and nothing has worked. I also changed a censor under the truck that would cause the tackometer not to work ( neither the tackometer or the WTS light are working). I checked the oil late last night an noticed that it is low ( it was recently changed and fine). Could this ICP be the problem? If so how do I go about changing it?? Please any help would be greatly appreciated! Also new to Diesel engines :/.
Old Jan 4, 2014 | 11:35 AM
carltonwebb's Avatar
carltonwebb
Check the fuses, including the large maxi fuses.
Old Jan 4, 2014 | 11:39 AM
Blh4488's Avatar
Blh4488
I've checked all fuses as replaced the big black ones ( maxi fuses). Still no WTS light and tackometer isn't working. Truck will not start. Read something about the ICP sensor and oil , noticed some oil leaking where there hasn't been any in the past.
Old Jan 4, 2014 | 11:41 AM
Bigtruc's Avatar
Bigtruc
Did u check both fuse panels, under the hood & in the cab? No wait to start usually points to the PCM not working, there is a fuse under the hood & one under the dash that power the PCM.
Old Jan 4, 2014 | 01:23 PM
Blh4488's Avatar
Blh4488
I've checked the ones under the good. Where's the one under the dash located ? Thank you for the help.
Old Jan 4, 2014 | 01:29 PM
carltonwebb
Immediately below the steering column is the insde fuses. 4 1/4 turn screws to remove the panel
Old Jan 4, 2014 | 01:34 PM
AllaboutMPG's Avatar
AllaboutMPG
directly under the steering column is a panel with quick release fastners. it's behind that
....... darn fast typers
Old Jan 4, 2014 | 01:47 PM
Blh4488's Avatar
Blh4488
Givin those a check. Thanks again for the help everyone!
Old Jan 4, 2014 | 02:12 PM
Bigtruc's Avatar
Bigtruc
Can't remember the fuse number under the dash but do know it is directly tied in with the fuel bowl heater. Powers that & the PCM so if that fuse is blowen then u most likely have a shorted fuel bowl heater.
Old Jan 4, 2014 | 02:25 PM
Blh4488's Avatar
Blh4488
Ok fuse 30 was bad. Getting a new one now. Gonna test it wen I get back home. If the heater is bad where do I go from there? You guys are life savers!
Old Jan 4, 2014 | 02:34 PM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1
For now you can leave the heater unplugged with no issues except the water in fuel light won't work if you get water in the fuel bowl. I replaced my heater with the revised version from the later model trucks. I got it from Clay at Riffraff diesel for about 40 bucks.
Old Jan 4, 2014 | 02:50 PM
Blh4488's Avatar
Blh4488
It worked !!! It's getting in the single digits here tonight. Should I worry about the heater till I can get it replaced? You're a life saver ! Thank you do much!
Old Jan 4, 2014 | 03:28 PM
Bigtruc's Avatar
Bigtruc
I wouldn't worry, I live in northern MN & we have been dealing with temps in the -30 range for the last 4 weeks & my heater has been removed for the last year. Never have been able to get a clear answer on what the exact purpose of the fuel bowl heater is but my truck starts & runs just fine without one.
Old Jan 4, 2014 | 03:52 PM
Blh4488's Avatar
Blh4488
Thank you for the info. Now I've got another problem. Took it out to drive after gettin it running and the brakes are making a buzzing noise when I push on them and it's sputtering. Any ideas. It was running great before the fuse blew.
Old Jan 4, 2014 | 04:39 PM
Bigtruc's Avatar
Bigtruc
The brakes r sputtering or the truck itself is sputtering? Buzzing noise from the brakes could be an ABS issue. Back track all your fuses again & make sure all r good & in the right place. I accidently put my airbag fuse in the wrong slot while checking fuses once & took 2 days of farting around before I found my mistake & got my airbag light to go out lol.
