Tach question
Old Mar 10, 2015 | 05:29 PM
maytag906's Avatar
maytag906
Tach question
I replaced the non tach instrument cluster in my 84 F 150, with a cluster with a tach from an 86. The tach did not work, but worked when I hooked it up direct before installation.
If II decide to hook up the tach direct, do I need to insulate the leads from the cluster printed circuit? I'm thinking there might be some feedback, or something nasty like that.
Old Mar 10, 2015 | 06:20 PM
Eddiec1564's Avatar
Eddiec1564
Did your old cluster have the full gauge set and no idiot light for oil and temp?
If full gauge cluster, the swap should be plug and play unless something was changed under the hood.
Old Mar 10, 2015 | 06:23 PM
maytag906's Avatar
maytag906
The 84 had the gauges, looks similar to the 86 one pictured.
Old Mar 10, 2015 | 10:09 PM
Jrcrispy2's Avatar
Jrcrispy2
There is a plug under the hood that needs to be wired to the distributor. your truck should iirc have a two pin plug on the drivers side near the firewall that has a green and black wire the green wire goes to the coil and the black gets grounded unless the distributor is grounded internally. Your harness should already be wire for it from there to the cluster. Someone correct me if i am wrong on this.
Old Mar 11, 2015 | 06:25 AM
JimsRebel's Avatar
JimsRebel
Originally Posted by Jrcrispy2
There is a plug under the hood that needs to be wired to the distributor. your truck should iirc have a two pin plug on the drivers side near the firewall that has a green and black wire. The green wire goes to the coil and the black gets grounded unless the distributor is grounded internally. Your harness should already be wire for it from there to the cluster. Someone correct me if i am wrong on this.
"the distributor is grounded internally"
change this to.... unless it it a six cylinder engine.
Jim
Old Mar 11, 2015 | 02:10 PM
maytag906's Avatar
maytag906
I'll look for it!
Old Mar 11, 2015 | 06:11 PM
maytag906's Avatar
maytag906
Got it
On the inner fender under the master cylinder, there were 2 connectors that went together, but looked like they had never been connected. One had a black and green wire. Hooked 'em up, the tach worked!
Thanks, all!!
Old Mar 11, 2015 | 08:13 PM
trevisM's Avatar
trevisM
Thought that was a plug and play.
Old Mar 11, 2015 | 09:01 PM
ctubutis's Avatar
ctubutis
As with most things, "it depends" is the correct answer to that.
Old Mar 12, 2015 | 06:00 PM
maytag906's Avatar
maytag906
No doubt!
Rogue_Wulff
159
Nov 20, 2017 07:32 PM
Flat250
Apr 20, 2013 01:42 PM
tempest411
Nov 21, 2012 11:33 AM
Anafiel
47
Nov 26, 2010 11:19 AM
chuckczrxoa
2004 - 2008 F150
Dec 21, 2007 10:56 PM
