Temperature gauge
Old Mar 8, 2015 | 09:21 PM
83sd's Avatar
83sd
Temperature gauge
The other day I noticed the temperature gauge in my expo was not working. Decided to dig into it today. The gauge has actually rotated around and is stuck against the stop peg. I took the cover off, rotated it back, and reinstalled. Tested it several times and it worked great. Got in the truck to run some errands and when I started it I watched the gauge spin all the way back around. Any Idea what the issue is? All other gauges work like they should.
Old Mar 9, 2015 | 09:41 AM
alloro's Avatar
alloro
The temperature sending unit or the wire going to it could be shorting to ground.
Old May 24, 2015 | 12:07 AM
83sd's Avatar
83sd
What is the usual operating temperature for the cylinder head temp sensor? I'm used to seeing around 200ish from a standard ect sensor. I was screwing around with the autel today and I'm showing a reading of ~312*F . The engine is definitely not running hot.
I'll be tearing into the truck next month to do a timing set , v cover gaskets, intake, plug boots, plugs, t-stat , cht sensor and a coolant change. It has a slight rattle on startup and I'm thinking it may be the chains being a little loose.
Hotairjunkie
Modular V8 (4.6L, 5.4L)
Jul 31, 2015 08:56 PM
geearturi
Aerostar
Dec 9, 2012 01:30 AM
jahollis2380
1978 - 1996 Big Bronco
Sep 20, 2011 09:49 PM
10-4 Crash
1983 - 2012 Ranger & B-Series
Feb 8, 2007 08:54 PM
jdbeetle
Mar 28, 2000 01:25 PM
