The reason to unlock the hubs is to increase fuel economy and save wear and tear on front drive links. Fuel economy increased due to vehicle having less mass to push around. When you unlock, the wheel just turns around the hub.
Would rather have the 4wd other vehicles have and have had for the last few decades in which you do not have to get out and rotate hub locks.
Can't defend it, don't see the point.
If you don't want to have to get out and lock the hubs to put it in 4WD, then just leave the hubs locked in and use your transfer case selector to choose between 2HI, 4HI, and 4LO as you so desire. I wouldn't recommend doing leaving the hubs locked in when running highway speeds since the transfer case wasn't designed for that, but if you are just running around town and other relatively low speed (<50mph) travel, it should be fine to leave the hubs locked all winter and then unlock them come springtime.
Other 4WD vehicles that have had shift on the fly 4WD for the past few decades almost all have CV axles in the front and a central axle disconnect. The CV joints are designed to run for extended periods at highway speeds, whereas the ujoints on your front axle really aren't designed to handle that kind of constant high speed use.
I have seen front axle ujoints and transfer cases detonate on rigs where the hubs were constantly left locked. If you choose to leave the hubs locked for the winter, just make sure that you do a thorough checkup of the transfer case, front driveshaft and front axle ujoints before and after the winter season to catch any wear early and get it dealt with.
