Sponsored by: Real Truck
superwinch hubs
Old Mar 5, 2018 | 07:36 PM
huskyfan68's Avatar
huskyfan68
superwinch hubs
yes I know they are garbage-- but I cannot afford new ones..... been on a truck a few years (2001 F250)- the one side was easy to select "free" and "locked" no issue- the drivers side would not "free"- (of course now I need 4wd......)- I took hub out and cleaned it- When I try and put the first piece back in (lining up the splines) it will not go in all the way on axle... Makes no sense...... it should just slide on??? Am i missing something? Also- the front tire is still in "locked" mode even without the hub (when I raise truck off ground both wheel and axle spin (which I thought was good)- when I select 4wd it does not kick in...... Am i missing something here?
Old Mar 6, 2018 | 07:09 AM
FractureCritical's Avatar
FractureCritical
lock the other side and spin the wheel without the hub. you just might not be overcoming the friction in the seals.
Old Mar 6, 2018 | 09:03 AM
huskyfan68's Avatar
huskyfan68
other side is locked- when i jacked up drivers side- both wheel and axle spin together (which would tell me it's "locked") so to speak...........
Old Mar 6, 2018 | 12:27 PM
FractureCritical
stick a long screwdriver through the u-joint in the knuckle and turn the wheel. it will turn or it won't.
speakerfritz
Mar 15, 2015 10:32 PM
phifer8390
Feb 18, 2014 12:43 PM
04xcur
May 11, 2009 09:47 AM
CAPTAIN 3747
Dec 8, 2004 08:02 PM
cwb
Offroad & 4x4
Jan 18, 2004 02:34 PM
