to hot!!
Old Mar 8, 2015 | 03:16 PM
96dreams's Avatar
96dreams
I'll pick one up from Ford tomorrow. I know it was the same brand and style that I pulled out of it. I just don't understand why it's so much hotter with the new one.
Old Mar 8, 2015 | 05:56 PM
96dreams's Avatar
96dreams
Ok everything is in and it's warming up right now.oil pressure was at 45 psi on start up. I'm at 150 f after about 10 min of idiling. Volts are at 14.
Old Mar 8, 2015 | 06:19 PM
96dreams's Avatar
96dreams
I went for a ride around the block and to the other side of town,about a 20 min ride. Pulling into my drive way I'm at 235 f.Radiator is cool to touch, the top hose is cool also but is very firm like it has pressure in it. The degass tank also has pressure in it.bottom hose is a little warm. Motor don't feel to hot when I run my hand over the top of it. So if my t stat was working right my temp should have stayed around 200 right. Its also about 65 out side right now. Oil psi was at 30 and 40 when I got on it hard.
Old Mar 8, 2015 | 06:24 PM
fordman67's Avatar
fordman67
If the upper hose is cold then either the t stats bad or rad is clogged.
Old Mar 8, 2015 | 06:27 PM
96dreams's Avatar
96dreams
Yes it's cold all the way untill it reaches the t stat housing.I'll pick up a t stat from the dealer and try it tomorrow and keep Ya updated.
Old Mar 8, 2015 | 07:56 PM
richdawg's Avatar
richdawg
In the old days we used to just put the thermostats in a pot of water on the stove and see if they opened, and at what temperature, a meat thermometer works good
Old Mar 9, 2015 | 06:27 PM
Pikachu's Avatar
Pikachu
^^^ This . . .
Old Mar 9, 2015 | 09:35 PM
96dreams's Avatar
96dreams
Ok the dealer t stat is in and the truck is warming up. Gonna take it for a little ride to the gas station and see what it does. The new t stat is a different design from the other one I bought. Deffintally more money but it's ok if it works.I'll keep Ya all up dated.
Old Mar 9, 2015 | 11:22 PM
96dreams's Avatar
96dreams
No more heating issues now, truck runs right around 190-200f. Thanks for all the help guys. Got to the dealer for a t stat!
Old Mar 10, 2015 | 07:55 AM
tjc transport's Avatar
tjc transport
i ain't rite
aftermarket t-stats are like glow plugs. the parts stores know they are garbage and do not work, but they sell them anyway.
Old Mar 10, 2015 | 01:21 PM
96dreams's Avatar
96dreams
Yes that's my next project I need to get done are the glow plug system. I'm.going to Ford for them.
Old Mar 10, 2015 | 01:42 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
Good call. You can also get a lot of oem parts from riff raff diesel. He's a site sponsor here and really good to deal with. Glad to hear you got it going. I can't believe you had 2 bad thermostats out of the box.
Old Mar 10, 2015 | 01:44 PM
  #28
96dreams's Avatar
96dreams
Ok, is he cheaper then the dealer?
Old Mar 10, 2015 | 01:49 PM
  #29
MOOSE_MACHINE
usually. It all depends on shipping. Check out his site
http://www.riffraffdiesel.com
Old Mar 10, 2015 | 01:50 PM
  #30
96dreams's Avatar
96dreams
I will for sure. Thanks for the help.
Fordbronco69
21
Sep 3, 2010 10:57 PM
lharriger
May 23, 2010 03:47 AM
G Guess
Dec 12, 2006 05:39 PM
F3Beam
16
Aug 8, 2005 11:22 AM
pronghorn_bill
Jan 20, 2004 07:14 PM
