dana 44 torque settings question
Old Mar 7, 2015 | 03:56 PM
maxride's Avatar
maxride
the Dana 44 front axle is on my 1984 f250. since the rotor needs replacing, I would like to have an idea of the torque for the inner and outer bearings and the hub nuts, just so this whole affair can be done right.
Old Mar 7, 2015 | 04:43 PM
roadrash63's Avatar
roadrash63
me too !!!!!!!!!!!!!
Old Mar 7, 2015 | 04:54 PM
Franklin2's Avatar
Franklin2
Use the special socket and tighten the first nut against the bearings while rotating the wheel to 50 ftlbs. Then back off 45 degrees of rotation.
Then install the lockwasher and the second nut, and tighten the second nut to 150 ftlbs. When the tire is installed, grab it at the top and the bottom, the play should be less than .006.
Old Mar 7, 2015 | 05:25 PM
maxride's Avatar
maxride
ah HAH! that's what I need to know. there have been so many conflicting ideas. this sounds really good. thanks.
Old Mar 7, 2015 | 05:42 PM
roadrash63's Avatar
roadrash63
thank you !!!!!!!!
Old Mar 7, 2015 | 05:44 PM
roadrash63's Avatar
roadrash63
hey you know the size of the socket 4 prong ?
Old Mar 7, 2015 | 07:25 PM
maxride's Avatar
maxride
the 4 prong hub nut socket is all we called it...for the Dana 44.
hail destroyer
Oct 31, 2017 06:46 PM
NorthToTheFuture
Sep 13, 2015 11:34 AM
five-0
Nov 11, 2009 10:00 PM
kjett
Nov 6, 2006 04:23 PM
omni
Jul 11, 2004 01:05 AM
