1994 XLT 4x4 f150, is the front diff a dana 44-IFS or 44-IFS-HD, I'm doing wheel bearings this weekend, and the torque values range depending on the axle. early model DANA 44 IFS / DANA 44 IFS-HD the torque is 50 ft lbs inner adjusting nut, and 150 ft lbs outer locking nut.
later model axles say unlock the adjusting nut locking splines( not sure what the adjusting nut locking spline is) then turn the nut clockwise to 70 ft lbs, then says disengage adjusting nut locking spline and back off 90 degrees, then retighten to 15-20 ft lbs, I gather on this later model theres is no lock washer and locking nut, can someone shed alittle light on this topic for me thanks Randy
