While looking for a replacment key set for my probably original key I seen one site asking if my truck was pre or post serial number C (i forget the numbers part). Mine is pre.
What are the differances between the two, other than the ignition switch (if there really is a differance)?
my key is very worn and it does stick while turning and or removing.
